BK XXLS400-FF with Marantz SR5011 and Indiana Line Tesi 560 — advice before buying
Rino
Hi everyone,
I would appreciate some advice on my system before purchasing a subwoofer.
My current setup is:
  • AV receiver: Marantz SR5011
  • Front speakers: Indiana Line Tesi 560 floorstanding speakers
  • Room: approximately 6 × 5 metres (30 m²)
  • Planned subwoofer position: beside the right front speaker, with some room to adjust its position
  • Subwoofer under consideration: BK Electronics XXLS400-FF
  • Quoted price: €715 new, delivered to my home in Italy
The system is used for both music and movies, but music reproduction is my main priority. I am looking for deeper bass and a smooth transition between the speakers and subwoofer, with clear bass notes and minimal boominess. Maximum output for movies is less important to me.
I would like to retain the option of listening in Pure Direct, although I am open to using Stereo mode with Audyssey if that gives better results in my room.
I am considering the BK’s high-level input for stereo listening and its RCA low-level input for movies, but I have not decided on the best configuration.
My main questions are:
  1. Is the XXLS400-FF a sensible choice for this system and room size, particularly for music?
  2. With the SR5011, would you recommend using the RCA subwoofer output and bass management for both music and movies, or using the BK’s high-level input for Pure Direct listening?
  3. If both inputs are connected, how should I configure the receiver and subwoofer to avoid duplicating bass?
  4. What crossover settings and placement approach would you suggest as a starting point with the Tesi 560?
  5. Are there alternatives around €700–800 delivered, including used models, that would offer a meaningful advantage? I have also considered the REL T/9x, but its new price is substantially higher.
If anyone has measurements or experience with this BK model, I would be interested in hearing about them.
Thanks for your help!
Rino
  1. Yes, for music it should definitely be enough. For movies, a sealed 12" sub might struggle to deliver room-shaking bass below 40 Hz. (Not a dealbreaker, but driving a sub with a relatively inefficient Class A/B amplifier rather than Class D seems a bit dated.)
  2. Yes, I would definitely use the RCA subwoofer outputs and let the AVR handle bass management. AVRs are very good at this, and proper room correction and integration are key to making a subwoofer sound good, since the sub and room effectively form a system. You can either use Audyssey (ideally with the €20 app) and experiment with different crossover settings, or use @OCA 's A1 Acoustix, which is much better and free.
    The high-level input is mainly useful when the amplifier doesn't provide a dedicated subwoofer output.
  3. Again, I would let the AVR handle bass management. I would set the speakers to "Small" so that they are high-passed above the crossover frequency. This relieves them of reproducing deep bass, which is what the subwoofer is designed to handle.
  4. I'd try a crossover somewhere between 60 and 100 Hz, perhaps starting at 80 Hz. For placement, I'd try the corners first, as they provide the most room reinforcement, but I would also try other positions if possible. Corner placement can strongly excite room modes, so room correction is important to tame the resulting peaks. If you use A1 Acoustix, it can determine the optimal crossover and integration.
  5. Personally, I'd also look for a used SVS SB-1000 Classic or Pro, XTZ 10.17 or 12.17 Edge, or Arendal 1961 1S. They all use Class D amplification and seem a bit more up-to-date in terms of design. However, bass management, integration, and room correction are much more important than the specific subwoofer you buy.
Thank you for your advice.
Just to clarify, my main priority is two-channel hi-fi music listening. Movie performance is important to me, but it is secondary: I see it as an additional benefit rather than the main reason for buying a subwoofer.
For music, I am looking for deeper, well-integrated bass with clear notes and minimal boominess, rather than room-shaking output for movie effects.
I also noticed that the REL T/9x uses a Class A/B amplifier. Would you consider the BK’s amplifier class a significant drawback in practice, or would you focus more on its measured performance and integration with my speakers and room?
It's not a significant drawback at all. Class D is more efficient than A/B, i.e. it will produce less heat and consume less electricity. In terms of sound quality, though, it won't make any perceivable difference -- particularly not for a subwoofer which only reproduces low bass notes.
What matters for "well-integrated bass with clear notes and minimal boominess" is proper subwoofer integration and measurement-based room correction. @OCA 's free A1 Acoustix does an excellent job in that regard and is pretty straightforward to use. I would definitely give it a try. If you don't like it, you don't lose any money and can always go back. Alternatively, Audyssey, which comes with the AVR, is decent too; and with the $20 app, you can tweak the target curve to your liking and switch off the nasty midrange compensation.
Subwoofers are simple compared to speakers. Basically, what matters is the SPL capability and bass extension you get per $. The BK Electronics XXLS400-FF seems fine in that regard and will work great for music. However, subwoofers couple with the room, and below the Schroeder frequency (depending on your room volume, roughly around 200 Hz), you are listening to your room which gets excited by the sub and the speakers. This causes massive swings in the frequency response, regardless of how flat your subwoofer performs anechoically. This is why measurement-based room correction is key to bring the massive peaks causing boominess under control.
Long story short: I'd buy the XXLS400-FF (or any other competently built sub) and connect it to the RCA sub out of your AVR, set the speakers to "small" to get them high passed, try out a few placements and crossovers, and focus most of the effort on integration and room correction with A1 Acoustix (it will also automatically determine the optimal crossover for you) or, alternatively, Audyssey.
Have fun!
Thank you for the helpful advice.
Regarding A1 Acoustix, is it compatible with my Marantz SR5011? Can I use the original Audyssey microphone supplied with the receiver, and do I need to purchase the Audyssey MultEQ Editor app? A link to a suitable setup guide would be very helpful.
Also, does anyone here own a BK Electronics XXLS400-FF or have experience using one for two-channel music?
I would be interested to hear which speakers you use it with, your room size, and how you have connected and calibrated it—particularly whether you use the RCA or high-level input and any room correction.
How well does it blend with your speakers for music? Have you encountered any difficulties with setup, boominess, or reliability?
For reference, my setup is a Marantz SR5011 with Indiana Line Tesi 560 floorstanders in a 6 × 5 m room. Music is my main priority, with movies secondary, and my quote for the BK is €715 new, delivered to Italy.
Any firsthand experiences would be much appreciated.
Thanks!
A1 Acoustix works with the Audyssey mic that came with your AVR. All you need is your computer (to run the script) and the AVR connected to the same network via wifi or ethernet cable. @OCA has a youtube video in which he explains how to use it. If your AVR has Audyssey XT or better, it should be compatible.
FWIW: Since you asked about experiences, here is a link to my first post on ASR about the experience I've had with my two modest systems. I wrote it when I was in a similar situation as you and learned a lot from ASR:
https://www.audiosciencereview.com/...s-kef-hts-3001-comparision-in-midfield.61329/
The main factor in having great sound in your room , is speaker placement and where you seat in the room.
So concentrate on that first, you might find that , for what you are looking for, a subwoofer is unecessary or even detrimental.
Once you have found a set up you enjoy, then it might be when exploring with DSP ( audessey) and adding a sub.
With what you have as speakers and not knowing what you room looks like, my guess is that you already all you will ever need to have great music in your room.
