Pdxwayne
- Joined
- Sep 15, 2020
- Messages
- 3,219
- Likes
- 1,185
I would say using this survey to validate Harman curve preference is a big stretch....I think "most people could identify the presence dip" is worded too strongly. But several people commented on the midrange of B and thought it was elevated - whereas it turns out that it was actually speaker A and to a certain extent D (the main competitors) which had less energy in the mids and/or presence region.
Below is how I framed it. It's not completely precise, of course, but I do think I perceived some objective characteristics of these loudspeakers. I perceived A and B as being most close to each others, which turned out to be correct - those are the two conventional box-speakers in the bunch. I thought D was more "airy" and "less direct" - these descriptors are not unheard of with electrostatic speakers (but I was wrong about it having wider dispersion, it rather has a different dispersion). I thought B had more midrange, and even though I didn't write it this was mainly in comparison with A, given that I went back and forth in listening between A and B after having ruled out C and D. Others had impressions of these speakers which turned to be even more precise.
B didn't fit the low sub bass requirements of the Harman curve anyway.
So, for the choices I have left (C is not a candidate):
*I select cleaner sound, but lack of sub bass and energy in certain bass notes
Or
*I select more full range sound, but lack of bass clarity.
In this particular case, I opt for cleaner sound and settled for lack of low bass energy.
B with a good pair of room eq subs? Yes.
A with better placement to improve bass clarity? Yes, I will select A over B.
