Binaural blind comparison test of 4 loudspeakers - II
Which speaker comes closest to the original recording?
  • Speaker A
    Votes: 7 25.9%
  • Speaker B
    Votes: 4 14.8%
  • Speaker C
    Votes: 3 11.1%
  • Speaker D
    Votes: 13 48.1%
  • Poll closed .
C
ctrl
.de, DE, DEU
I still don't understand why would the Grimm Audio measure in reality better when the KEF has the better spin?
We don't know that for sure. The KEF probably has better directivity in the treble range.
However, the Grimm has an very even sound power and PIR frequency response, especially below 1.5kHz.
... and the frequency spectra of the music recordings are not frequency response measurements.
Andreas007
Germany, Bavaria
I went against the crowd this time and chose B. It had the most natural timbre of piano. I noted that it was a bit bass heavy on other tracks though. Listening on the other speakers, the piano was just wrong. There must be some errors either distortion or in frequency response causing this.
I did also notice that the piano on B is quite different to the others, not timbre but attack. However, I put it into category “overemphasized”.
C
ctrl
.de, DE, DEU
in absolute values, no it's not. for comparison purposes it's essentially the same.
The spectrum of the original recordings itself is already extremely wavy and not comparable to a measurement with, for example, pink noise. Therefore, certain frequency ranges can convey completely wrong impressions.
PierreV
Room interaction? Grimm says they focus a lot on that in their literature. We all know, I guess/hope/think, that room interaction, positioning and orienting matters a lot in real life, especially for far-field floorstanders.
The endless discussions about a couple of dBs here and there in measurements are probably valid when one is discussing Genelec vs Neuman near-field monitors. But it is near useless, imho, to focus on those for far-field speakers where room interaction will dominate most other factors. What I am saying here is not that a science-based design doesn't matter. Just that the small differences we argue about aren't necessarily significant in real-life settings.
abdo123
Brussels, Belgium
I would typically agree, but here the speaker that received positive impressions also was the speaker that reproduced the spectrum with most fidelity.
abdo123
Brussels, Belgium
well it is obviously significant as D received the most votes. this sort of opinion would make sense when all 4 speakers recieves equal number of votes. obviously that is not the case and 'small differences' matter even in real-life settings.
Andreas007
Germany, Bavaria
I’ve heard the Grimm once at High End Munich, the last speaker audition of the day. I was blown away. My first thought was: “This is another level of performance compared to all the other stuff I’ve heard before during the day. This is soo different and sounds just right and natural. There is no speaker anymore, you don’t think about it. The music just flows!”
(Ok, there was no Genelec, Revel or Neumann before, just the usual audiophile suspects… :D)
Without the horrid price tag I would have bought them instantly! :cool:
I’m glad that I’ve voted for the Grimm again here. Seems that these speakers are doing something right.
C
ctrl
.de, DE, DEU
Agree with you. If you only look at the measured deviations from the original recording, then you can deduce how much it has been changed by loudspeakers and room (assuming that the recording conditions have not led to any significant frequency response changes) - plots from post#93
Extremely difficult is the interpretation of the plots from post#90, because of the ripples in the original spectrum.
abdo123
Brussels, Belgium
Wait i just realised that the Kef Reference 3 is not tuned flat :oops:. it's obviously now the worse measuring speaker.
Thomas_A
Sweden
So who is next on setting up a binaural speaker challenge? Very entertaining subject with both suprises and hopefully some learning. :)
PierreV
Let me repost the result of one of my first binaural recordings.
Two different floor standers. Lowest priced is at same price level as B&W/Grimm here.
Designs are very different. 2 is a 3 way with a front woofer, 1 is a 4 (or 3.5 depending on your definition) way with dual side firing woofers.
Both measure differently in the measurements I could find ( not Amir's quality measurements mind you, I don't see Amir putting 80+ kgs speakers on the Klippel soon.
Correlated null at 49.08dB
I did not even pay much attention to time alignment as you can see from the unaligned data
No EQ, that would defeat the purpose of comparing speakers.
The in-room positioning is obviously a bit different (but optimized for my taste) since they are simultaneously present, they have a lot of space to breathe (at least 1.5m at the back, around 3m on the sides)
I could theorycraft at length based on their differing stereophile and other sources measurements.
But in my case, at least, it seems that armchair speculation has its limits.
PierreV
Now that I have come to terms with the limits of binaural recordings and have prepared myself psychologically to the fact that my wonderful speakers will sound as poor cardboard boxes ;) I will try to come up with something. It may take a while as I need a silent house, maybe move heavy stuff around and, having teens at home isn't especially stress and noise free.
C
ctrl
.de, DE, DEU
If the measurements are presented in this way, I can also make no statement at all between the two speaker.
in the diagrams in the previous posts I used 1/3oct smoothing, which makes the interpretation much easier.
And if you have the spectrum of the original recording, then you can derive some more information.
C
ctrl
.de, DE, DEU
When the DIY speakers I'm working on are finished, I can imagine making binaural recordings from them (three different top speakers, one bass module).
It looks like one can rent a KU100 dummy head for 70€ a day. But that will be the case in a few months at the earliest.
PierreV
Oh, I am not sure one could. In fact, I would have sworn the differences between the speakers were very significant in a sighted test and, much to my horror, discovered I failed a blind test.
In fact, the idea I have is to come up with 4 different recordings and let you guys decide on the difference. I may throw a couple of outsiders in the mix, just for fun.
And for assured ROTFLs, include BOSE 901 Type6 ;)
I even have umik measurements, EQ data for when I run it, etc...
IMHO, this shows nicely how the room is the great equalizer below 500Hz, regardless of the design (assuming in both cases competent designs)
Tangband
Sweden
It could be that one or the other does not like the results. Therefore, right from the start, there is no conspiracy and the data were not manipulated by me.
The result of the poll:
Speaker A - Heco Direct (3000€)
View attachment 160090 View attachment 160094
Speaker B - KEF Reference 3 (9000€)
View attachment 160091 View attachment 160095
Speaker C - Bowers & Wilkins 802 D3 (22000€) (No manufacturer link found)
View attachment 160092View attachment 160096
Speaker D - Grimm Audio LS1 (22000€) with subwoofer modul
View attachment 160093 View attachment 160100
Source of the frequency response measurements is hifitest.de.
Source of the binaural recordings is German magazin lowbeats soundcloud.com database..
The current binaural recordings (by lowbeats.de) are made in an EBU-Tech 3276 compliant studio. The older recordings, used in our poll, were made in their own acoustically treated listening room (here is the link to the translation or use the translator of your choice). In the pictures you can see the typical setup.
Two MBHO small-diaphragm condenser microphones with free-field equalized omnidirectional characteristics in AB configuration were used for the binaural recording.
The current binaural recordings are performed with a KU100.
More details about their binaural recordings can be found here (here is the link to the translation or use the translator of your choice).
The best sounding loudspeaker in this test is apparently GRIMM audio LS1 . The only loudspeaker in the test that has dsp crossover and driven active. I´m not surprised at all. A good active design will always sound better, even compared with the best passive loudspeaker.
Tangband
Sweden
Clearly the KEF lost on its peaky bass. Otherwise it is the speaker that has a bit more energy at 2 kHz vs 3-4 kHz. Which may be one reason that I liked the piano from KEF more than from the others.
Kef has a coaxial design wich is no garanty at all to sound good, quite the opposite I would say.
This is an interesting blind test, but the result might be slightly different if each loudspeaker had optimal placement in the room. 15 cm more apart or closer together would make the sound quite different. Ofcourse the active system ( GRIMM LS1 ) has a hugh advantage in the beginning, because of much lower distortion in the EMK area ( because its active ) and a more frequency linear dsp corrected sound.
Thomas_A
Sweden
I would not be to certain. The GRIMM has very different design with wide baffle. The previous binaural challenge gave even higher diiferentation between speakers and it was a passive x-over in a Revel. The KEF has a very peaky bass and will be scored negative for that.
Tangband
Sweden
Yes, a wide baffle seems to be very good. You dont need to compensate for the baffle step. The first test didnt have any active loudspeakers at all, so its hard to know. The revel has very good directivity and are not a coaxial design.
A perceived ”peaky bass ” can also depend on problems higher up in frequency, or less optimal loudspeaker placement, or simple less good bass aligment with wrong tuning frequency in a bass reflex construction.
In a coaxial design, the perceived pitch of each tone will be slightly blurred and indistinct because of IM distortion in a bad design.
