My Shure//JICO SAS/B get about 11 Hz both directions with the UP-4 tonearm, which has (due to its construction) identical effektive mass laterally and vertically. With Linn Akito the resonance is 8.5 Hz vertically and 6.5 Hz horizontally. Also, the Moerch measurements of DP-8 with various cartridges places the vertical resonance quite high (due to the mass is very close to the pivot point). Results are between 16-20 Hz vertically, while the horizontal is virtually non-existent (high mass and high damping).No, it has a quite limited effect since the momentum is the square of the distance. 1 gram at 20cm has the same effect at 100 gram as 2cm
I will get my Denon 51F back from service next week , it has the Shure V15 IV with SAS/B, it will be interesting to check the vertical and lateral resonance then . I can defeat the servo arm…My Shure//JICO SAS/B get about 11 Hz both directions with the UP-4 tonearm, which has (due to its construction) identical effektive mass laterally and vertically. With Linn Akito the resonance is 8.5 Hz vertically and 6.5 Hz horizontally. Also, the Moerch measurements of DP-8 with various cartridges places the vertical resonance quite high (due to the mass is very close to the pivot point). Results are between 16-20 Hz vertically, while the horizontal is virtually non-existent (high mass and high damping).
Yes, the servo arm vs conventional arm should be interesting. Buy the Thriller album, use it as test record if you don't like the music...I will get my Denon 51F back from service next week , it has the Shure V15 IV with SAS/B, it will be interesting to check the vertical and lateral resonance then . I can defeat the servo arm…
It's a European (Holland) pressing Epic 85930 ("PAL 38112 HOL" in runout groove).Which pressing do you have?
I think we need a way to measure.Thanks for posting those great videos. It looks like the Grace actually bounces around a tiny bit more than the others. The difference is small, and the matching between the tonearm and the Hana and Supex may juuuuust be a bit better than with the Grace, but likely inaudible.
Yes. It occurred to me the cut may matter, this is a promo 45 single, bright red, and not sounding great.The 45 single might behave different though, another cut, another pressing. Would be interesting to see the signal recorded.
I've finally got around to capturing my LP (1982 Europe original pressing - bought at the time!)This is the beginning of Billie Jean. It seems that a LF around 8 Hz, in phase (lateral) comes after the large beat. It is in the region of resonance (11 Hz) and also higher in level compared to the song before. It does not seem to bleed from the music signal, and it is still possible that this is cut into the record. There is no way to know unless there is another forum member that could test the same using an arm with high mass in the lateral direction.
And spectrum:
Spectrum for the song before:
Yep, but the 8 Hz peak is -40 dB down from the ≈50 Hz peak on the CD version vs. +3 dB on the vinyl. But noted, it is the same f.IIRC that’s the right frequency.
The HP filter of the Duo is quite steep so it might be comparable to my result.I've finally got around to capturing my LP (1982 Europe original pressing - bought at the time!)
As you can see, very little extreme LF component: This is a Decca Gold VDH on Rega RB300 on a belt-driven Townshend Rock with the damping trough. All fed into a Cambridge Audio Duo (with non-defeatable High Pass filter) being captured by an RME ADI-2 Pro FS BE sampled at 96kHz. I've put in a post 22kHz filter due to some noise.
I've also added a spectrum analysis showing the LF peak at 8Hz, but about 12dB below peak.
Due to the trough - it's hard to view the cartridge end-on, but there was very little movement and certainly nothing like the original video which I think shows something broken or wrongly setup.
