- Thread Starter
- #21
I'm not sure I understand the question (it's hard for me to understand the text)
I have an audio pro add on 8" 150 watt 35hz crossover 60hz
Sometimes when i play at 100% from my wiim amp pro i want a little higher limit from my subwoofer = cleaner less distorted bass
Sound is faily clean from my main speakers but can happen to distort from my subwoofer, for the bass to follow my main speakers with no distortion in 99.9 % of the time, i need/want a subwoofer with higher limit
If my sub where in a 10" version i might try to find one
It's only at the most extreme just shy of party level i need more headroom,higher limit + just keep up with my main speaker until they get 100% and don't distort noticeable
If my sub where a Dali sub E-9 F i would look for a Dali Sub E-12 F, if i had a B&W ASW 608 i would go looking for a ASW610, just a level up in power,limit so very loud music is cleaner with less distortion do to a higher limit,headroom from the sub
Crossover of 60hz helps my main speaker play loud and amiri say the wiim amp pro might have a limiter since it at 100% don't distort.
Like with some floorstands speaker you can get some distortion before the twetter and midrange reach it's max spl with the amp you have
You therefor need 1 or 2 sub (and a crossover that cuts the deepest bass from the main speakers HPF) or bi amp (if possible) the speakers for less distorted bass at high levels.
My max spl is determend by my amp and main speaker
