Pretty much the same for me. 55 years old and hit 13,40050s and I top out just above 13k
quite a bit down from even 5-6 years ago
BTW: the linked generator is quite handy to quick-testing comb filtering - just set a frequency and move your head.
I have to do this to catch 18 kHz near-field from the tweeter. I suggest people do this if using speakers because it may not be your hearing, just the position causing these frequencies to elude you. Of course you should just use headphones.Plug one ear with a finger and it will be really obvious as you move your head.
With two speakers playing, it's also interesting with both ears open, with higher frequencies (500 Hz +).Plug one ear with a finger and it will be really obvious as you move your head.
Yeah that's how it is. Anything above 8 kHz isn't important for speech recognition anyway, which is what hearing aids are usually intended for. 300-3000 Hz is the usual speech range (which is why old 8 kHz sampling rate digital telephone transmission was really good enough).I'm 69 and can't hear test tones above about 10kHz anymore. I doubt I'm missing much. My experience certainly isn't tragic. Someone correct me if I'm wrong, but I think once you've lost sensitivity above 8kHz no hearing aid is going to restore it. Your flesh and blood mechanism for detecting it is just not there anymore no matter how much it gets amplified.
I'm also 74 and I can also get to just under 11kHz - but I have to turn the volume WAY up above 8kHz.Thank you, that one's very convenient - or am I saying that just because I got a nice result?74 years old and still good up to nearly 11kHz.
Correct. But most EQ options limit the amplitude, thus protecting the user from himselfCareful when turning up to hear higher tones with speakers. Most tweeters don't like high level tones, the little voice coils get hot and can burn.
Another reason to test: I have a ZERO area between 7K & 8K that I discovered by doing an online FR test & then reversing the headphones left & right. The blank zone stayed at the same ear, so not the headphones.I always tested above average for hearing as a young man so imagine my surprise when I went to the website below and heard nothing. I posted this in my Mind Blown thread as well, but it has made me realize I need to visit an ear doctor to see if hearing aids would be recommended for me or if it's just part of normal aging so I thought it deserved it's own post. Anyways here's what I learned today:
. . . I visited the website below and heard absolutely zilch. Looks like I'm unable to hear sounds above 8 kHz or so AND it turns out that's probably true for the majority of us old fogys. Looks like time to visit the ear doc and see about hearing aides
I asked chatgpt: " Can you estimate the percentage of folks over 50 who can no longer hear frequencies above 10 kHz?" and this was the answer
Yes — estimating the percentage of adults over 50 who can no longer hear frequencies above 10 kHz falls within well-studied territory.
Estimated Percentage:
Why?
- Roughly 60–80% of people over 50 have a noticeable reduction or complete loss of hearing sensitivity above 10,000 Hz (10 kHz).
Supporting Evidence:
- Presbycusis (age-related hearing loss) starts in the high frequencies, typically above 8 kHz, and worsens with age.
- Even by age 40–50, many adults begin to lose the ability to hear above 12 kHz.
- By age 60, the upper hearing limit often drops to 8–10 kHz, even for people without noticeable hearing "problems."
- Standard audiograms for aging populations show the average upper hearing limit:
- ~12 kHz for people in their 30s.
- ~10–11 kHz by their 40s.
- ~8–10 kHz or lower by their 50s and 60s.
- Some individuals over 50 may still hear slightly above 10 kHz, but most will have a steep drop-off.
Bottom Line:
If you're estimating how many people over 50 cannot hear above 10 kHz, a safe and realistic figure is:
This should be factored in for any application involving audio design, alarms, or communication systems targeting older adults.
