- Joined
- Aug 5, 2021
- Messages
- 572
- Likes
- 621
This is true but I would prefer XLR pre outs rather than RCA.
Same here
I'm not a big believer in this "it cost more and therefore sounds better", people who buy into this BS are just plain dumb.You’re forgetting that “signature” Marantz sound![]()
I can understand that, but the Denon has a usable display.If they're essentially the same, I prefer the look of the Marantz significantly over the Denon. Not $800 significantly mind you![]()
Most suffer when they add complexity to their multichannel system. If you add PC, AVR and external amp with ground in the mains, you can expect some form of ground loop. Might not be obvious, but it might be there.if you suffer from ground loops...
Advantages of optical Hdmi.... (and SPDIF)Most suffer when they add complexity to their multichannel system. If you add PC, AVR and external amp with ground in the mains, you can expect some form of ground loop. Might not be obvious, but it might be there.
Better a lower SINAD XLR then a high SINAD RCA.
That will be a big $$$ item...
I presume that you will need to step up to A1 level prepro (from either D or M) to get XLR outs...
All for questionable actual audible benefits.... (under most normal circumstances... if you suffer from ground loops... huge benefits!!!)
Prepro's of interest might come out from Onkyo and Integra (I believe that their Pioneer Stablemate will be AVR only) - and if they follow recent trends, the prepro's will cost a bit less than the equivalent AVR...Can't find the post now but I'm pretty sure that someone claiming to have insider knowledge suggested that SU plans to differentiate Marantz as higher-end relative to Denon, and as a result pre-pros (with xlr pre-outs) would, going forward, only be available from Marantz.
Based on these helpful pictures, the 4800H's max. power consumption is rated at 710 W compared to 660 W for the 3800H, so only a 50 W difference, although the former's channels are rated at 125 W vs. 105 W for the latter. Based on the sister Marantz Cinema AVR specs, these models will likely consume 100 W when idle. (I plan to measure and report that power consumption after my 3800H arrives tomorrow, and especially vs. the number of internal power amps "switched off," which I suspect means only the disconnection of the signals from the pre-pro, rather than the actual reduction/elimination of Class A/B bias in the output stages.)
Assuming that the "70% guarantee" still applies to these new Denon's models (same as it applies to the new Marantz Cinema AVRs), the actual total power with 5 channels driven will be 5*125*0.7 = 438 W for the 4800H and 5*105*0.7 = 368 W for the 3800H. Assuming that about half of the 100 W idle power goes to the pre-pro and the other half to the power amp, the 3800H's efficiency would be 368 / (660 - 50) = 60%, which is in the ballpark of Class A/B amps can muster. For the 4800H, that would be 438 / (710 - 50) = 66%, which is perhaps a bit of a stretch (even though, I believe, the 4800H is supposed to have a beefier transformer and maybe bigger block caps).
What does the back panel power consumption rating mean?
- Unless it says "max power" don't assume it's a max power rating with all channels driven.
- ·According to Sound United, they follow IEC 62368-1 electrical safety standard for rating power, specifically Annex B for operating conditions and Annex E for test conditions.
- Amplifier to be tested at 1/8th unclipped de-rated power @ 1kHz & rated load impedance.
- Sound United follows IEC 62368-1, the electrical safety standard for audio, video and similar equipment for their AV receivers.
New "monolithic amplifier" design of X4800H, similar to the A1H. X3800H retains the current design.
For me, I'm happy I have the AVC-X4700h despite the rather 'low' DAC's... as the 4800 has the same. Yes I would have liked the HD interface, the 4 sub pre-out's, the 'monolithic' amp's, the improved ADSP, the 'built in Japan'-label, the 'full 8K support on HDMI-in' and the improved power supply but..... I don't wanna pay € 1,200.00 more for basically the same machine... I will never use 4 sub's, have my 4700 installed using the Denon app, never drive my system with 11 power amp channels, for a long time to come use 8K as there is so limited input. The € 1,200.00 I spend on a € 699.00 Marantz MM7025 power amp, a big Warfedale sub and a really good Wharfedale center. So I can relax now I know I made the right decision a while ago. Still I'd like to know the advantage of the monolithic amp's; I you look at Amir's test it doesn't bring anything in SINAD between let's say a 6700 or even 8500 and a 3600, 3700 or 4700. Can anyone explain what the advantage should be and that I am missing the point?
The 710 W consumption is not "maximum". Denon and Marantz never provide the maximum figure like Yamaha's. For Yamaha's you can find their maximum consumption in the owner's manuals but for D+M's I cannot find it anywhere, not even in their service manuals. So we don't really know what Denon's maximum power consumption, and we don't know what the basis is for the 710 W (for the X3800H) shown on the back of the case. Gene has written about it on Audioholic.com and speculated how they came up with number, but that's just his speculation based on information he obtained from Sound United though it sounds reasonable to me.
Receiver Power Consumption Rating vs Output Power Is Not Watt You Think!
Ever wonder how your favorite manufacturer rates power consumption on their AV receivers and how it relates to maximum available output power to your speakers? The answer may surprise you so read on.www.audioholics.com
I believe 15A already includes a safety margin. In reality they can handle bursts of 16, 17, 18 amps. Just don't do it continuously.If that is true, it is a safety issue. That is because most residential circuits are 15 A, which means 1,800 W, and other devices are typically plugged into them. Every device should have a clear specification of the max. power consumption to avoid circuit overload (a safety margin of at least 20% is recommended, which reduces the standard line to 1,440 W).
The electrical service. Not individual circuit in the home.Sure, the circuit breaker will tolerate a short-term overload (the size of which rapidly diminishes with duration), but...
"Generally, it's recommended that the load never exceeds 80 percent of the electrical service's capacity."
Oh boy. In the electrical jargon, service = circuit. Another article for your reference:
How to calculate your circuit loads: Avoid overloading your circuits
"For a good rule of thumb, do not exceed eighty percent of the maximum rated load. Refer to the vacuum example. For a fifteen amp circuit, the safe load is 1440 watts. For a twenty amp circuit, the safe load is one thousand nine hundred twenty watts."
If you still are not convinced, google "max recommended load of electrical circuit."
Not really, 15 A circuits are rated 15 A continuous subject to the 80% service capacity rule, the key word is "continuous". Audio amps, AVRs are not light bulbs or electric heaters that could be operated continuously, literally. Very different kind of loads that cannot be compared directly..
FWIW, I took the dimensions of the 3800H's power transformer from the French presentation the other members posted. I am not sure exactly what the "96 x t65" means, but assuming it is the size of the transformer core (as opposed to its exterior) and plugging these numbers into a sample transformer calculator (while keeping the core efficiency at the default 0.82) results in the core area of 6,240 mm^2 and the apparent power of 2,058 VA. Assuming a power factor of 0.75 (cited in Gene's video/article other members posted), the real power would be 1,544 W translating into 12.9 A on a 120 V service line, which exceeds the recommended max. 80% load of 12 A.
(Further assuming a 92% efficiency of the unregulated linear power supply, the internal circuitry would get up to 1,420 W. Subtracting the aforementioned 50 W for the front-end would leave 1,370 W for power amps. At a 65% efficiency, they could yield 822 W. Of course, these are just back-of-the-envelope calculations, as the parameters of various "nannies" inside the AVR are unknown.)
