Old_School_Brad
- Joined
- Sep 10, 2024
- Messages
- 1,864
- Likes
- 2,641
I’m not saying EQ can work miracles and fix every speaker. We’re not living in a world where a Jamo 365 magically can be made to sound like a Revel Salon. That said, EQ is still a super useful tool for improving sound quality. Sure, it can’t solve physical problems like resonances, cabinet vibrations, or bad transient response, but it’s great for fixing frequency imbalances. It can smooth out peaks and dips, make the sound more balanced, and even help with room issues.Point #10, the one that Toole highlighted, is what you are disagreeing with. And while it may seem possible to EQ every speaker to better performance, that's just not the case, as explained in point 5. You really can't EQ a resonance. Perhaps you can EQ one aspect of it's radiation pattern, like an on-axis peak at a given frequency, but you will then introduce other on- and off-axis artifacts. Even if you can get one slice of the field EQ'ed with on-axis performance that is OK in one position in the room, you are left with other a host of other problems, sometimes worse than the on-axis performance you EQ'ed.
Resonances are hard to deal with in any system, not just speakers. They uniformly defy equalization, require good design up front. I tested an old Yamaha speaker with a rigidly mounted Styrofoam woofer that operates as a resonant membrane, and is a good example of a speaker that cannot have it's issues EQ'ed.
I recommend thinking deeply about point # 5 in Toole's post, and then about EQ.
No, EQ won’t fix a poorly designed speaker or turn a cheap one into a high-end model, but it can still make a big difference, even with budget setups. Most speakers whether they’re good or bad will sound better with some EQ, especially when it’s adjusted to fit your room, preferences, and listening position. This ties back to my earlier point about active speakers that come with different tunings or "house curves" built in.
