D
Deleted member 2944
Guest
This is why I used the terms "perfect world," and "conditions," and put "double the power" in quotation marks.I am familiar with the discussion. He does not ever say you get twice the power AFAIK, but does explain the potential "effective" increase within the range of the amplifiers, or words to that effect, through frequency division (splitting). IOW, a driver might get the full 100 W in one band (e.g. bass), unencumbered by any signal in the other (e.g. treble) band, but will not see 200 W. That is the thing many fail to grasp; two 100 W amps do not allow you to drive either band to 200 W, it is not the same thing as doubling the amplifier's power. The real-life advantage possible depends greatly upon the speaker design, crossover frequency, and source frequency (spectral) content, natch.
Alas, even that potential is lost with so-called "passive" biamping as implemented by most AVPs/AVRs. In those cases you can argue current headroom is gained, though it may be minor, but essentially no practical increase in voltage headroom, thus essentially no real-world benefit assuming decently low amplifier output impedance and cable resistance.
You are correct that using a second identical power amp will not increase the peak voltage capability beyond a single amplifier. However, adding the second power amplifier and then band-limiting both amplifiers by moving the system crossover upstream does yield a real advantage in current usage. Whether that might amount to 3db is indeed related to the real-life possibilities you mention. (Many variables here.)
I don't disagree with you on the potential of "passive biamping." It's a marginal improvement, at best.
Dave.
