I'm baffled as to how "broken in" pads can cause a change in treble measurements.
After a few months, they start absorbing energy in a very specific treble region?
It's pretty obvious to hear on my DT-880, you don't need measurements to confirm it.
Old pads sound less bright and a bit more muddy.
I had the effect multiple times over the years, whenever I switch to new pads because the old ones fall apart, the can suddenly sounds a lot brighter.
It's probably just the foam going flat and changing the distance to the driver or sth.
And yes: I agree with the Oratory quote: the DT-880 gets uncomfortable to wear once the pads are flat enough that your ear constantly touches the foam above the driver.
I was talking about driver burn-in rather than wear-in of the pads, that dude's YouTube video references 3-year-old pads which is pretty ridiculous.
That's why I specifically mentioned burning them in without wearing them, to separate the driver burn-in and pad wear-in - considering so many people are talking about the DT990s after burn in I thought it'd be a good platform/experiment.
Burn-in occurs over the first few hours of use of a new transducer. Everything beyond that is happening in the listeners head.
That's because you have no clue how wrong you are. Harman tuned headphones have been popular for decades before Harmans researchers started working on the target, and remain references to this day. Case in point: Sennheiser HD600 and HD650. A clear pattern emerges when looking at many highly praised headphones that happen to follow Harman: Focal Elex, HIfiman HE4XX, Beyerdynamic DT 250, NAD Viso HP50.
The target is not some novel curve, it's in effect a consolidation of headphone manufacturers internal targets used for their best sounding models, whether tuned by ear or measurement device.
And yet, it is still a preference target. So there will be people out there who do not like the sound of it.
While it is a sensible place to start and use as a reference to make educated guesses, please do not think of it as gospel that applies to every person 1:1.
