Sorry Amir, but I mean DT 1990 PRO, Not the DT 990 PRO. They are highly recommended by some "youtube subjectivist audiophiles" as one of the best headphones in the $500,00 range. It would be awesome if you could review them! Thanks![/QUOTE
I wish it sounded as good as it looks.These were unofficially voted the most beautiful headphone design by ASR members as well
Indeed, there were so many variations that I got somewhat confused (although after hearing an un-EQed 250ohm version I spared myself the trouble of looking any further)The DT880BSE has more lows but sounds too muddy for me.
BSE comes close to the DT990 in sound signature.
That one improves by using the grey pads.
Depends on seating position thoughIf you've ever gone to a live indoor orchestral classical music concert and listened to a concert bass drum you would never say "...lighter music such as classical, orchestral...".
I went to a concert recently which used them. I was floored by the impact and volume, thinking I could never reproduce this closely at home.If you've ever gone to a live indoor orchestral classical music concert and listened to a concert bass drum you would never say "...lighter music such as classical, orchestral...".
If the concert hall is poorly designed...Depends on seating position though
Practically speaking, impossible to reproduce at home....but I suppose if money were no object, etc, etc. If that were the case, you would be better served traveling around the world listening to the finest orchestras, in the finest halls.I went to a concert recently which used them. I was floored by the impact and volume, thinking I could never reproduce this closely at home.
With the balanced pads and a bit of EQ to tame the treble peak, the 1990 is one of my favorite headphones.I wish it sounded as good as it looks.
Just the impedance different ones do not cover "all" of the DT880. There is at least also the chrome version, pro version and black editions of the pro premium and regular versionsOne thing good about Beyerdynamic is that they sell nearly every individual replacement parts for their headphones.
Anyway, of all the DT880s, the 600 ohm has been the more "liked" headphones of the lot (32, 250 and 600 ohm) so I guess the fact that the frequency-response curve hugs the Harman curve for a majority of the range says quite a bit. But no other "reviews", by subjectivist or otherwise, have mentioned the low end distortion yet (perhaps I wasn't paying attention) but most have noted the overall "brightness" of the Beyer's tuning. So thanks Amir for objectively showing that (Also Solderdude's test).
Also, the chap at "Youtube - No themes review" has mentioned that high output impedance amp (100ohm) is the way to go for driving this headphone well from his tests. I do not understand the science behind this but Beyerdynamic's own very expensive A20 headphone amp has very high output impedance (100 ohm) so I think it kinda make sense if one presumes Beyer knows how to match their products. Such high output impedance amps go against the grain of the vast majority of the "top of the class" amps tested by Amir. (The above chap recommended the cheap Samson s-amp which has 100 ohm output impedance as an suitable low cost match amp for this headphone.)
Just the impedance different ones do not cover "all" of the DT880. There is at least also the chrome version, pro version and black editions of both the pro and premium version
Na, Solderdude has already measured at least one to be different DT880 Black Special Edition | DIY-Audio-Heaven (wordpress.com)I thought these were cosmetics variations only with the main guts (driver etc) staying essentially the same (mainly 250 and 600. I don't think the 32 ohm version had specials). Some have been limited runs so are currently unavailable anyway.
The DT880 Edition = DT880 Pro but with other looks. It differs substantially from the DT880 Black Special Edition.For posterity here's Oratory1990s measurements of DT880, DT880BE and DT990.
Whenever a headphone has a variable impedance, then using a high impedance headphone amp will modify its frequency response. Here the modifications would be rather small so I think there are other factors in play (assuming the audible impressions are real).If there is a logical scientific reason for this, would testing the headphone on different output impedance amps yield a different result? Would the distortion result change?
I think the clamping for is different. Pro having higher clamping force. And this also causes tonal changes. Pro is smoother and thicker sounding, edition/premium edition sounds more open and trebly.The DT880 Edition = DT880 Pro but with other looks. It differs substantially from the DT880 Black Special Edition.
The Pro and Edition are basically the same headphone but with a different enclosure and cable.
Below the DT880 Edition vs the DT880 BSE.
Either blind, or never seen thr Empyrean.These were unofficially voted the most beautiful headphone design by ASR members as well
