Never tried one. A bit out of my price range.What about the various Dan Clark Audio models?
Are they still shielding and grounding the cables? I heard it affects their high end frequencies by a tangible amount, though couldn't hear any difference when decoupling my t1s.Downside is the cable resistance for the coiled cable is way too high (audible effects in stereo imaging) and the headphone is very output resistance dependent
900 pro x is the most neutral of the mentioned ones and would be my choice when no isolation is needed. Otherwise the 700 pro x, which is a tad too forward between 1 and 2 k.Hello. Please tell me which headphones are better for writing arrangements, production, beats, and easy mixing: the dt1990/1770, the dt1990/1770mk2, or the dt900 pro x? Some people recommend the 1770 because it doesn't have a sharp top and has plenty of bass, but is this true? Please share your thoughts and opinions.
If you have to choose between Дт1770/1990мк2?900 pro x is the most neutral of the mentioned ones and would be my choice when no isolation is needed. Otherwise the 700 pro x, which is a tad too forward between 1 and 2 k.
Very likely the 1990 but even the mkII is quite treble heavy, albeit a bit less than its predecessor. The original 1770 lacked a bit clarity, the mk2 is better in that regard, but bassier and a bit treble heavy too.If you have to choose between Дт1770/1990мк2?
Оказывается,It turns out it's better to take DT 1990 second revision Than 1770?Скорее всего, 1990, но даже у MkII довольно высокие частоты, пусть и чуть меньше, чем у предшественника. Оригинальному 1770 немного не хватало ясности, Mk2 в этом отношении лучше, но он басовитее и с чуть более высокими частотами.
Если изоляция не нужна, я бы почти всегда выбрал открытую заднюю часть. Но я не большой фанат баса, так что ваши предпочтения могут отличаться.
Actually, I'm just confused about which ones to choose. If the second revision has bright high-pitched sounds, it might be better to go with the original 1770. Does the second-generation 1990 sound too much?Very likely the 1990 but even the mkII is quite treble heavy, albeit a bit less than its predecessor. The original 1770 lacked a bit clarity, the mk2 is better in that regard, but bassier and a bit treble heavy too.
If no isolation is needed I'd almost always go for the open back. But I'm not much of a bass head, so your mileage may vary.
Beyer have always had a treble hump the 1770 mk 2 is supposed to be less bad than the mk 1 in this regard.Actually, I'm just confused about which ones to choose. If the second revision has bright high-pitched sounds, it might be better to go with the original 1770. Does the second-generation 1990 sound too much?
Hello. Please tell me which one to choose between the dt1770/1770mk2 and why? They say the 1770mk2 is bright. If I have to choose between the dt900pro x and the dt1770/1770mk2, which one should I buy?Beyer have always had a treble hump the 1770 mk 2 is supposed to be less bad than the mk 1 in this regard.
1. It makes no sense to repeat the question if no one answers within a few hours.Hi! Which headphones should I buy, the dt1770 or the dt1770mk2? Which is better, the top or the bottom? Or should I consider the dt1990mk2? Is the mk2 worse than the original?
Under consideration are the 1770/1770mk2/1990mk2/900 pro x. Which of these pairs should I choose?
