Maiky76
I asked ChatGPT Pro to give scores and plot the components of preference score for Clarity 66 speaker and compare it to Ascilab C8C. The results were quite a bit more understandable to my eyes:
The key to visual clarity is the normalization of each component as to best it could be.
What do you think?
Any representation has its own pros and cons, the radar plot included…
First task would be to define the dimensions.
You have decided to use the component of the score and the score itself:
PPR_ON = 12.69 - 2.49*NBD_ON - 2.99*NBD_PIR - 4.31*LFX + 2.32*SM_PIR
Second one would need to define a scale for each dimension you you’d like to plot
Then you can define the % of the scale that the device is reaching then convert to grades F->A+
The %->letters relationship does not need to be linear IMO but based on bins at least.
@amirm pointed that already.
One more point is the population to be displayed many speakers score in the 4-6 bracket.
We need more dynamic than that...
Dimensions:
- the Score itself self-explanatory but not straight forward
If one only consider 1Hz as the “best” then the maximal score would be 12.69.
If one set the “best” to be 14.5Hz (as for the SW score), then the max score is 10.
Even using 10 as the top score we don’t really see anything above 7 and some devices have a negative score…
So the dynamic would be limited.
- Bass extension
As mentioned 1Hz is the default "best" but it can be set to 14.5Hz.
There no “worst” so one would need to decide what the bottom of the scale is.
e.g. 80Hz there are psychoacoustic and practical reasons for that but IMO a bit low especially with micro monitors which can’t play loud at LF but still provide decent overall presentation.
160Hz? i.e. AM/FM receiver could be a reasonable bottom of the barrel for “HIFI”
- ON - axis smoothness
From the original Score equation the best is 0dB that gives the 100% but no real bottom line
- In room response “smoothness” SM_PIR (from 0 to 1 best) and PIR smoothness NBD_PIR (best 0dB)
- PIR smoothness NBD_PIR Both are metrics derived from the same curve i.e. PIR which pertains to the in-room response they should be lumped together IMO. Even their current name is confusing
SM_PIR is how the PIR is captured by the LINEAR regression. With constant directivity, some speakers could be SEEN as smooth but not measured as smooth, I am not sure I would call it that.
https://www.audiosciencereview.com/...urements-community-project.14929/#post-467858
You could ask the AI to retrieve all the scores and metrics values from the plots so far and and ask it to come up with something and more importantly justify its choices.
