Hhm, not sure I do understand this, REW has only JAVA or ASIO.
Anyway, cross-recording didn't work for me with either configuration, MT-->REW or REW-MT, see post
#830, always got the artifacts in the recorder application even when the simultanueous recording in the program that ran the generator was 100% OK.
Important note on the issues seen in that post #830. There is no change when I use MT's own generated signal saved to file (32bit, with 64 it's working OK)
WASAPI/ex creates the familiar artifacts when left at 0dB during playback. Any other always gain gives correct result (as long as I don't clip).
The source file is clean whan throwing it a REW.
==> MT's import seems to do something odd... which is fixed with a small gain change (for WASAPI, at least)
And time to report two other quirks:
- external test signal file is not reloaded even re-selecting it... making it awkward to test variations of the test signal with the same name. I have to load a different file, start measurement, abort it, and finally reload the test file.
- the red "sample-rates doesn't match" info is never cleared when sample rate does match again.
