- Thread Starter
- #4,621
It's probably ADI's input sensitivity as it's adjustable.
Check this out too.
Turns out the issue was a simple calibration setting in MTA (level calibration factor) that was set to +10dB. Issue's solved.
Check this out too.
Hi Álvaro,Hi, I'm new to Multitone. Just downloaded it yesterday and started testing it, but I can't find any tab or preset related to the "LP" measurement. I'm trying to measure wow and flutter from a test tone in WAV format.
Could someone point me in the right direction?
Regards,
Álvaro
Thanks, Paul. I managed to add the LP tab, but when I try to load the attached wav file, I get this error.
What am I doing wrong?
Thanks again.
Álvaro
modulated_tone.wav
Thanks! It’s working now.It's not you, it's me
Looks like one of the recent UI changes to accomodate floating plot windows broke the update of the LP plot. This new version should fix the issue. Download and run the installer (v1.2.12)
https://app.box.com/s/ue7ll9xmvwogst817x2l1xg09opvgy47
Let me know if you're still having problems:
Is the value shown as Weighted (DIN) an RMS measurement?
Cheers!
Hi @pkane,
I recently did my first steps with Multitone and I'm impressed. Great work
I read that test plans are supported but opening the menu I can add my own but no defaults are given.
Is there a file available where I can for example automatically run test to get results same as those from @amirm?
If such a file (or something like the @amirm measurements) exists it would be great if you might share that.
Best DrCWO
Hi @pkane,
Best DrCWO
Thank you for that. Started the Plan for my RME ADI-2 PRO FS R but after running for quite a while Multitone stuck here.Not quite Amir's AP measurement plan, but you can start with the test plan I used to measure the latest RME converter. The plan is attached at the end, in a zip file: https://www.audiosciencereview.com/...to-measured-with-multitone.43243/post-1531201
You may need to make some adjustments for levels, etc.
It looks like it's done? Did you try to click View Test Results?Thank you for that. Started the Plan for my RME ADI-2 PRO FS R but after running for quite a while Multitone stuck here.
Any idea?
Best DrCWO
It's stuck at the J-Test and that's by far not the last test.It looks like it's done? Did you try to click View Test Results?
Yes, try again. It looks like it didn't get all the data it expected from JTest input deviceIt's stuck at the J-Test and that's by far not the last test.
There is not much in the result folder..
I'll try again and do nothing else with the PC during the measurements.
Best DrCWO
Same resultYes, try again. It looks like it didn't get all the data it expected from JTest input device
Or try running JTest without the plan and see if it goes through. You may need change some of the parameters, possibly warm-up time.Same result
Will try without this test now again.
So far it now runs without the J-Test. What I wonder about is that the display in my ADI-2 Pro always shows approx. 11dB less as Multitone shows in its processing box. Any idea?
Hmm, there is nothing in MTA that prompts you to wait longer. Something else is going on. Is that a Windows message by any chance? That test plan step used a 4M FFT size (as I wanted to see the DC filter behavior well below 1Hz). 4M FFT can be a very heavy lift for some CPUs, especially laptops. I'd suggest you adjust it to 1M or even lower for this step.With the Log Sweep FR (4M) test that takes quite long it asks me if I like to continue. Pressing Yes I see this error report.
Hi Paul,By the way, you may benefit from using the updated version of MTA I posted -- this has some fixes for UI-related issues that could cause plots not to be updated resulting in that error message you posted. Please try it (v1.2.12):
