Beta Test: Multitone Loopback Analyzer software
Hello! Is possibile to calibrate the sound card without REW software?
Sure. Run a log-chirp through your system, then export the result using Menu->Export->Frequency response as text. You can use that file as a calibration file in Multitone settings.
Just a quick fix to remove automatic clipping of Intersample-over test signals for @NTTY:
https://app.box.com/s/u50vkuk0nzotyg9hl2nd0g1izh673i4r
Don’t expect this to work a 100%. It’ll work but there are known cases where it will not update all the detached windows correctly.
So far it works for me ,strangely didn't manage to break it .
But I'll keep trying!
You are just not trying hard enough! ;)
Try this one:
1) Take a measurement, for example "1000Hz sine"
2) Change to "External Source" and take another measurement
3) Switch back to "1000Hz sine" and take a measurement
The player doesn't start anymore:
To fix this, you'll have to take an extra measurement between steps 2 and 3 to be able to measure 1000Hz sine again (It must be something else than the first measurement).
For example this sequence works ok:
1) 1000Hz sine
2) External source
3) 10kHz sine
4) 1000Hz sine
Now the player works again as expected when using 1000Hz sine.
Try this one:
1) 1000Hz sine
2) Extrernal source
3) 10kHz sine
4) 1000Hz sine
I was talking about breaking the new windows feature!
But yep,replicated yours and broke it just fine.
Hi, I tested the ISO files, exporting to 16bits 44.1kHz, as this is what I need, but there is clipped signal:
Cheers
Hi, yes, this is because the signal actually should not reach the actual 0.69dBFS level, it needs to be just below it. The preset play gain value is a bit too high for this test. I'll fix the preset in the next update.
The actual values for play gain not to clip are as follows:
5512.5Hz: 0.687dB
7350Hz: 1.249dB
11025Hz: 3dB (this one is correct)
I'll adjust these in the presets in the next release.
For now, if you change play gain to 0.687 for 5512.5Hz, you'll get this result:
which looks like this in the waveform view (this is reading the 16 bit generated file):
There is a copy/paste error in the tooltip for detachtable windows too:
Don't spend too much time testing the detached windows, unless you really want to for fun :) As I said, it's not finished, plot updates are still broken in a number of places.
FYI, Multitone seems to be calculating ENOB wrong by 0.5 bits (too much). You're in good company though, REW has the same problem with 0 dBFS definition (which should be fixed in the next release). Also, how can TD+N be lower than N+D or -SNR?
On a 1280x1024 screen @ 120 dpi and Win7 (my office PC), the UI is not a happy camper. The results OSD is largely disappearing offscreen (as is the "measure" button, meanwhile the audio device fields are suuuuuuuper wide for no reason), and once I select a 0 Hz lower frequency limit, the results OSD goes on vacation altogether, both on screen and in the captured plot. It reappears once I redraw and open or close the Settings Panel.
At least the "Capture Plot" function gives me a complete plot including the parts poking out offscreen.
For illustration: That's a 1000.003 Hz tone of amplitude 0.999969 at 16/44 undithered, Freq 0 to 22050 Hz. It should pretty much be the very definition of 16 bits.
Hi @pkane !
The history window seems to be partially broken in the latest version.
If you select (
), deselect (
) and select again (
) the same measurement, the graph won't come back any more.
This happens again if you choose another measurement and repeat the same steps.
You can reset the view by taking a new measurement or double-clicking the old measurement in the history window, but you still can't reselect the measurement.
96k I/O,64k FFT,no window and log-chirp won't stop after measuring but proceeds to a new one and a new one,etc. (does not stop)
(haven't ticked the "repeat" ,I checked twice! )
Ah, yes. I was in the process of adding averaging to the log chirp process. Try setting the number of averages to 1 for now, to have it not repeat.
Hello Paul,
Long time has passed...
I hope you are doing well.
Question: when I generates a calibration file, I get the usual text file. I can upload it also to REW and even import it to see the frequency response curve.
Is is possible to do it also with MTA?
That is to import the txt calibration file and to see the frequency response curve?
Something strange, I see the values in the file itself but the values seen by REW are not consistent with what written in the file, e.g. notch dept.
Last, what is the latest version? Clearly there is an auto update and the latest is version 12 but it seems for long time...
