- Thread Starter
- #3,801
Just noticed that through my post here:
Actif analog crossovers
Seems to me there are lots of benefits to using actif analog crossovers over DSP crossovers, if you are using a Dac to convert to analog then using a dsp, are you not converting back to digital? Can't be good. If you are using an actif analog crossover you don't need a 8 chanel Dac. Also with a...www.audiosciencereview.com
Why SNR is so different in this version between MTA and REW,they used to be very near.
(hope it's not me messing stuff as usual)
Can you please check this REW setting in your set up and make sure it's unchecked?
When checked, this makes the peak of a full-scale sine wave +3dBFS, and results in a higher SNR result in REW. Multitone always treats 0dBFS as the peak of a full scale sine wave, and not as RMS level.
