I still can't get my math right...
When watching the spectrum view as a dBFS scale, the graph shows the peak value, right?
And when I calibrate the Voltage, I measure it with my multimeter (Fluke, it should read RMS Voltage) and insert it to the dialog:
Now when I measure the spectrum with a Volt scale, it shows the same Voltage I just added:
Should this show a
peak value and
not the RMS value I just added to the Voltage Calibration dialog, just like the
dBFS view earlier?
If I calculate the 1,41421356237 * 13,246V =
18,73267284715302 V which is my peak voltage (I think) and add it to the Voltage Calibration dialog, the
Spectrum view now shows the peak Voltages and the
Level Sweep now shows the same
(RMS) Voltages as my Fluke multimeter and shows the same Power levels as I calculate from the readings from my Fluke Voltmeter and my clamp Ampmeter on the dummy load.
If I use the
RMS Voltage reading of my Fluke to calibrate the Voltage, Level Sweep shows
half of the Power calculated from the Volts and Amps of my meters.
Could you please check the code, if the calibration Voltage should be inserted as a peak Voltage and not as a RMS Voltage?
