Beta Test: Multitone Loopback Analyzer software
morillon
have you made a simple measurement of a 12khz at -3.01db in 48/24...?
out of curiosity...
Sokel
In the Windows mixer?
But you are using ASIO in all captures, I don't understand how the Windows mixer can have any impact on the measurement in this case
I thought so too until some months back that we disgust it here.Strangely mixer works for Khadas but not for E-MU.
out of curiosity...
Like that?
pkane
pkane
North-East
Some drivers let the Windows volume control directly adjust the hardware level in the DAC. I assume that’s what happened here.
Grooved
Thanks, I was afraid it was also routing the signal through the Windows mixer in his E-MU interface
Sokel
Wait now,I was only talking about the previous measurement.
Because E-MU's dac is also routed through and you can adjust it.Only ADC is immune.
pkane
pkane
North-East
A few updates and fixes in v1.0.56 of Multitone:
Changes in 1.0.56
  • Add: RMS and RMS(A) result display
  • Add: IMD (multitone) distortion panel that includes TD+N, SFDR, Noise, IMD, ENOB and other results
  • Fix: Missing information text on copy plot to clipboard
  • Change: backround display for the distortion information panel
  • Change: auto-adjust result button display to fit all the text
  • Change: Improved IMD calculation now works with multitones with up to 64 tones (was max of 5 previously)
Here's an example of the new distortion panel for multitone test signals:
Level vs. IMD sweep using a 5 tone test signal:
Sokel
An error appears to me after measurement saying "VoidOxuplot.PlotElement.set_fillColor" and the display information panel is missing :cool:
Edit:...and because of that can't do Level vs IMD,stops after the first measurement.
morillon
well done...!
is it possible to allow a more precise adjustable gain...?
for example a-0.1dbfs etc.
define a "precise number" to enter directly?
example
as a precaution, it is sometimes useful to put this very slightly below 0dbfs
the case is present there is little with a small streamer hardly supporting the signals generated .. and it possible to propose in 24bits and not 32bits?
Sokel
well done...!
example
You can type any gain you like.
You can also type in the other fields.
morillon
sorry then...
I was just watching the "play gain" on the main window...
(I can hardly use multitones for driver problems .. what a pity ...)
Sokel
sorry then...
Yes,in the main window play gain you can type whatever you want in the box without choosing.
In many other boxes too,try them.
Fix your drivers,Multitone is great!
morillon
it's stupid I didn't realize that it was possible to enter values directly in these small windows.. thought that just scrolling menus
:oops::oops:
I think it's just lost on the driver side
and when I see what pkane produces as permanent evolution on soft, there is no question of making him waste time on this kind of nonsense..
(between rew, often for generator,very comfortable but much less rich multitones, and my virtins pro I still have solutions
in "play gain" precise can chose if "dbu dbfs or volts" can be cool
the fonction "lock frequency to rta fft" and new "monitor clock match" in rew seem smart
pkane
pkane
North-East
Hmm. Seems like again an older version was somehow uploaded, as I did find and fix this issue before the last update… let me see if I can figure out why that’s happening, as it’s not the first time.
pkane
pkane
North-East
:oops::oops:
Hi Morillon,
If you're having problems with a driver, please post the details (unless you already know that the driver is broken :) )
Lock frequency to FFT is automatic in Multitone, you don't need to set it.
