Don't make me confess the alien E-MU engineeringI thought you’d prefer no noise!
Can you please test this version: https://app.box.com/s/qbrh3czrvudclkqs9n8lm806k3hzmjx5
This has some unrelated changes that are not fully baked yet (always working on the next thing!) but I think it might resolve the issue with the last average in your measurements. Fingers crossed!
The additional vertical units are most welcome!
The scale could be larger, with around -55 dB gain the Voltage goes to 0,01 V -> 0,00 V because there is only 2 decimals visible:
Depending on the load the Power goes to 0,00 W even earlier:
Could there be more decimals or even better, could the unit change to mV, uV or even nV when needed and the same with the power units?
And another.
When you click a history entry you get the chart without legends.
If you double click you get the chart with legends but they are wrong,usually 3db higher or lower.
Ok.Double click reloads and reprocesses the data as if it was just captured from the audio device. The result replaces any measurements on the plot, including any legends.
Selecting a history entry adds that entry to the current measurement, so legends, if any, will continue to reflect the current measurement and not what you add from history. This is by design.
As to 3dB difference, can you please show an example?
That one is fixed. It was due to the number of averages that was different between the initial run and what the recalculation from history produced. Restore from history could contain more averages if there were sufficient samples at the end of capture.I can't replicate @Sokel's report, but I can confirm that there's some variation with the history files and the original measurement.
For example: I made a measurement and the level inside the circle is about -136 dB:
Then I closed MT, started it again and opened the "History" -window and double clicked the last measurement of the previous session which should show the same graph as above. But no, the peak is not the same any more, now it's -137 dB and the colored graph (Blue) doesn't match the normal white graph of the same measurement (The larger red circle, the white graph is partially visible under the blue one). The phases of the harmonics are all over the place. Even the peak of the white graph is not the -136 dB as it should be:
Then I opened the "History" -window again and double clicked the same measurement again. Now the peak is still at -137 dB, but the blue and the white graph are mysteriously perfectly aligned. The phases of the harmonics match the original, but the graph looks more like the second picture then the first one:
Is the avarage calculation so accurate, that it should show exactly the same graph as the original measurement when double clicking the history entry? How about the values? There are 0.1 - 0.2 dB differences between the original measurement and the same measurement calculated from the history (For example the harmonics)
Try exporting a history entry,close,open from the entry and see if it happens when you double click on the history entry with the chart empty.I can't replicate @Sokel's report, but I can confirm that there's some variation with the history files and the original measurement.
That’s also fixedThere is a small bug when changing from dbFS to dbr,the first time changing it results in a strange chart,if I keep changing it it goes normal.
(that's for the same existing measurement.)
I get the same 3db difference and what's odd is that every future measurement from then on follows that -+3db unless I hit the X button with brings the next measurement back to normal.
Also with 44100 sample rate is like an little harder than it was,it jumps a little fast and not as gracefully (note the language please ) to the next average until it finishes.
Change between dbr and dbFS is now perfect.
