I hadn't - I assumed we can only choose from the list, like how you can't export 24bit - needs to be 32/64bitDid you try to type it?
try typing it. Can't guarantee it'll work, but it may depending on how fast your computer is in processing FFTs.I hadn't - I assumed we can only choose from the list, like how you can't export 24bit - needs to be 32/64bit
no, that's just for recording.I only want to save a .WAV file
Does this still need CPU powah?
For generating offline files, is there any reason it needs to be linked to sample rate of an output device?no, that's just for recording.
Can the offline file generation be independent of devices ?
Sometimes I get crashes when I have to start the recording, to create offline file. Even when I try to stop the recording.
Noted, but now that it can generate so many cool things, it has overtaken REW .Sure, anything is possible, but the point of Multitone was not to generate test files, but to run loopback tests
Update to the preview version 1.0.49:
https://app.box.com/s/qbrh3czrvudclkqs9n8lm806k3hzmjx5
To add a new display variable, the logic and the formatting is the same as it is for titles:
- Some bug fixes for the reported issues
- Added Amplitude Spectrum Density display option (scales spectrum display per sqrt(Hz)) to remove the effect of FFT gain on noise floor
- Added the ability to create new, custom display variables in Results window
https://distortaudio.org/multitone-exp.html
Since this is a somewhat advanced feature, I thought I'd just record a video showing how to use this. Watch most of the action in the Results window:
20 60 0
20000 60 0
@pkane Out of 6 bugs I reported: Four are fixed and two are not fixed .
This is one of the old bugs, ENOB is still printed wrongly on the "Results" -window (when using the calibration file). It's correct on the "Spectrum" view:
You don't need to hook up the APU to verify this, only add this calibration file:
20 60 0 20000 60 0
Of course all other values are 60 dB off without the APU, but you can see the ENOB difference between the "Results" -window and "Spectrum" -view easily.
Thanks for reporting this one. I decided this was not worth a fix. If you want a blank chart — click the red XThis is the second old bug:
If you change both of the measurement to "none" with the sweeps, it still shows the last graph when there shouldn't be anything visible.
The first measurement is IMD, the second TD+N.
This one is done like this: First the Measurement #1: IMD -> none, then the Measurement #2: TD+N -> none. And TD+N is still visible:
This one is done like this: First the Measurement #2: TD+N -> none, then the Measurement #1: IMD -> none. And IMD is still visible:
Is there a way to do the 2 channel calculations or is it still on the development state?
Seems that only the left channel field is editable.
{tdn-60}db is obviously only for the first channel and gives the left channel value for the current right channel and an error for the previous right channel measurement:
{tdn-60}db and {tdn2-60}db give the right values, but I'll have to use two rows and of course there are 4 wrong values visible (the white ones):
I think that {IF(channelNumber=0, tdn-60, tdn2-60)} should do the trick, but channelNumber gives value "0" for both channels and it shows two times the left channel value.
{IF(channelNumber=1, tdn-60, tdn2-60)} gives two times the right channel value, so the "IF" -conditional statement seems to work ok.
That would make sense for me.
But you'll need to redo that YouTube video then
