- Thread Starter
- #21
I have a i5 6600K and all the four physical cores are used when it freezes and has glitches.
I have to try again with other outputs, it happens with the standard Windows DS for sure and I am using EqualizerAPO for both headphones/IEMs and desktop speakers. But if I recall I changed output too and I think I had the same issue in WASAPI (exclusive and shared) but I didn't test properly and maybe it is just DS.
I just tried ASIO, WASAPI and DS, the CPU utilization stays around 10% even if I continuously move the slider up and and down. If you can see which process is using up all the CPU in task manager, that will help me. If all four cores are used, then it's not Earful. It uses up to two threads at any given time, so can't take up 4 cores
Here's what I get while continuously adjusting volume slider playing into a DS driver
