- Thread Starter
- #301
Its is viable to do the 32-tone multitone test on speakers like in DAC/AMPs?
Sure, why not? You may need to be careful with levels, possibly apply a pink tilt to the multitone to not burn out the tweeter.
Somehow I didn't get the notifications about these posts, sorry about the late reply! But yes, I did add this and produced some results that showed the effect and a few A/B tests.Is there a version available for Linux?
Any chance of distortion vs frequency be added?
I looked for this information, but the search terms I used probably were not the right ones, because I didn't find the answer. I apologize in advance.
Jitter on the conversion clocks in mixed signal applications usually is a combination of amplitude modulation and phase modulation. They are oscillators, after all.
Does Distort add amplitude modulation, phase modulation, or both? I'd like to investigate the effects of phase modulation off the clock at low frequencies.
Thanks!
Jitter is a time-domain effect that impacts the timing of samples in a recording or reproduction. It can be viewed as amplitude modulation of the original signal with some other, undesirable signal, that may be correlated or uncorrelated with the the real content. DISTORT provides the ability to define the corrupting signal as a set of individual frequencies and amplitudes, as noise, or as a correlated signal at some specific amplitude. The corrupting signal phase is currently not controllable through DISTORT, although would be easy to add.
Well, "phase noise" on conversion clocks can be both amplitude related as well as phase related. For example, a slow frequency drift over time would be phase related and not necessarily show up as sidebands on each converted tone over a single FFT "sweep" time. If it's easy, or you're plain curious about it, adding that capability to DISTORT might be revealing. Emphasis on might.
I do know that loudspeaker cabinets physically moving, even a little, has an effect on the perceived sound. Could electrical modulation of the waveform phase cause something similar? Dunno, and I haven't found much research on this. I could be bad researcher, though.
What you're describing is more like wow or flutter type of an effect, and is a large issue with vinyl/LP playback and mostly non-existent in digital.
Is it?
I had some friends who got very interested in clocks. They tested a zillion clocks, both commercial and designed by them, using lots of different crystals. They found that they could hear differences in perceived sound. They couldn't detect any measurable differences in the audio testing or with standard RF testing of the oscillators. It drove them (more) crazy over at least a year.
Eventually, they purchased a test system that used cross correlation to measure Allan variance down to hundredths of a Hz. They found that the best sounding clocks had much lower phase noise below 1 Hz than the others. All else was pretty much the same.
Keep in mind that they did the audibility testing first and were perplexed by what they heard so they then did more extensive testing. So, no biases upfront and the test equipment had no biases, either.
This was not DBT or any of that, but they were convinced.
These were not fancy audiophile clocks either. They all were typical commercial oscillators of various kinds and, as I said, ones they built. Even within the ones they built, different crystals from the same vendor and same lot had very different low frequency phase noise performance.
Anyway, I'd personally like to explore what this might be about. Adding a varactor modulated by an external voltage to a clock crystal in a DAC might allow the same thing, but it's less controlled. And way more tedious.
I can also tell you that in telecommunications systems, low frequency wander is a thing...
Maybe consider astrophotography or something.
so sad they omitted the chance to make real audio headline shocking news by proving this is audible...This was not DBT or any of that, but they were convinced.
Is it possible to show how something like the GFA565 monostrapped at power levels greater than those of the testing of that amp?Somehow I didn't get the notifications about these posts, sorry about the late reply! But yes, I did add this and produced some results that showed the effect and a few A/B tests.
In order to simulate larger levels of distortion at higher levels, I'd need to see some measurements at that power output. I can then adjust the settings in DISTORT to reproduce the same type of distortion, including any variation with frequency.Is it possible to show how something like the GFA565 monostrapped at power levels greater than those of the testing of that amp?
The reason I ask is that when you look at the spectrum of distortion, you see the 5th and higher ordered harmonics down quite a lot compared to the lower orders. I would predict, based on seeing that, that the amp would 'sound' fairly smooth. Usually when I've heard 'brightness' in solid state amps, its been at higher power levels. I do have to point out that at my age, I'm not hearing nearly what I could 40 years ago. A lot of solid state amps I'm hearing these days don't seem to 'sound' all that bright...
It would be nice if the apps had Icons with a bit of color that are visible on a black start menu background.
You patch the icon in the binary.Good point, although only Earful icon appears to need more pop, at least to my eyes:
Search isn't showing me anyone asking for this: 2-tone intermodulation distortion please?My plan is to build more distortion generators into DISTORT over time, from different filter types to jitter, to variable group delay and some others. All with the same goal in mind: to determine at what levels these distortions become audible. Any suggestions on which ones you'd like to see first are welcome.
Search isn't showing me anyone asking for this: 2-tone intermodulation distortion please?It's been getting annoying to me how much importance people give to the Klippel test's results even though it doesn't explain on the page that the music stimulus is practically irrelevant, only the 2-tone should be used, and also it uses a weaksauce 2-tone with 70 Hz and 800 Hz tones, putting the main IMD products far from the frequencies most of us are maximally sensitive to. It would be nice to have a superior tool to be able to do a proper 2-tone test that shoots for our most sensitive areas (tries to kick us in the audio nuts if you will).
We could use a default setting like 2k + 5k stimulus so it creates IMD at 3 and 7, or if it's not too much work, put in an adjustable sweep so we can find our personal frequency of maximum sensitivity (maybe if we can tweak the limit frequencies of the sweep and slow it down as much as we want) and then have it calculate on its own what 2 tones to use to create maximally audible IMD products (hopefully all falling in the high mids to mid treble area).
