re. drag and drop of files
OK, just tried it. Dropping a single file anywhere within the DW surface places the file in the 'Reference' field. OK. Dropping two files places them in the 'Reference' and 'Compare' fields respectively. IMHO what is really needed is the ability to drop files, one at a time, into either the 'Reference' or 'Compare' fields from entirely different places on the system. In other words, how about making two smaller drag and drop zones, corresponding to the text entry areas for 'Reference' and 'Compare'? A very good example of this is to be found here [in the "single file" tab].
Your current scheme is good only if the two files reside in the same folder (unless I have missed something).
That's there. Go to Windows Explorer, pick one or two audio files, and drop them onto DeltaWave
