Folks,
Only for the brave: I'd like to solicit your feedback and suggestions on DeltaWave null-testing software. It's an early preview, so please be gentle!
Details and software download are available here: https://deltaw.org
An example report produced by DeltaWave comparing two USB cables (warning: large file)
Some quick points:
Some quick points:
- Runs on Windows 64bit, requires .NET 4.6
- The faster the CPU, the more cores, and the more memory - the better
- Meant for analyzing differences between two audio files captured with something different in the audio path, such as a different power cable, usb cable, DAC, preamp, DDC, ADC, digital filter, power supply, etc., etc.
- Similar in some ways, but hopefully better than Audio DiffMaker. This is completely my own design and implementation, started because I could never get DiffMaker to work
- Finally, the software is completely free of charge, but the current beta version will expire in 60 days. By that time I'll have an updated version posted on the site
- Reads DSD, FLAC, and WAV file formats, writes difference files as WAV
- Plays original and difference files over WASAPI (ASIO in the works)
- All computations are performed in 64-bit floating point format
- Matches phase to sub-sample accuracy, removes clock drift, and matches levels (non-linear level matching is also supported, but consider it experimental)
- Will resample to the same frequency if two files are not sampled at the same rate
- Generates delta waveform, spectrum, spectrogram, phase difference, and cepstrum plots with zooming
- Produces a full HTML report documenting the results of a comparison, including how close to bit-perfect the two files are
- Supports low- and high-pass filtering of the files, as well as notch-filter to remove a specific frequency
