OK, let's give this a try. I suspect there will be cases where not ignoring silence at the start will result in a larger mismatch, but then, it's an option and can be turned on and off as desired
https://app.box.com/s/hlglgy3aj39rjfxu343fho4t0cdrq9v8
The setting looks like this (and is turned ON, by default to be compatible with how it worked before):
The result with my recording chain looks like this (raw recordings, no alignment done). With this setting ON, as it was previously:
And with the setting turned OFF (silence is not ignored at the start):
Let me know how it works out, I'll make this an official release 2.0.9 if it works for you.
Thank you SO much!
Worked flawlessly when using ASIO with
RCA->RCA -connection. I matched over 6 minute track two times, both runs were perfectly aligned with the reference and all 3 tracks were exactly the same length, by a single sample. I call it perfection!
However I still have a problem. I usually use the
optical output of my sound card to feed my
DAC (to prevent the ground loops when measuring amps) and it uses ASIO channel
3 and 4 for the optical output (
RCAs are 1 and 2). DW doesn't support more than 2 ASIO channels, so I'll have to use the
VB-Audio ASIO Bridge to convert ASIO channel 3 and 4 to
WASAPI channels 1 and 2 to be able to use my setup with DW:
This adds a significant delay (About 1.5 seconds) to my chain (Reference, ASIO and my converted WASAPI below):
This seems to be too much for DW to align the tracks. Cutting a half second off from the start of the WASAPI recording with Audacity seems to help.
@pkane do you have any plans to add support for multichannel devices to DeltaWave just like you did with MultiTone?
It can be a little bit trickier however because DW uses the predetermined channels (L, R, stereo, L+L, R+R, R+L, L+R)...
A native multichannel support would make DeltaWave perfect!
