PHD
- Joined
- Mar 15, 2023
- Messages
- 298
- Likes
- 450
Hi
A few years back, I almost killed my Focal Aria when I stepped on the RCA cable connecting my Denon pre-out to my Hypex Ncore power amp.
Because the Denon uses a 2-prong AC while the Hypex amp uses a 3-prong AC, and the interconnects are single-ended, the only galvanic signal ground path is through the RCA cables. So if the RCA connector becomes loose, the signal ground is lifted, generating a loud buzzing noise from the speakers.
The way I see it, there are two possible ways to avoid this issue:
1. Add a grounding post (like one found next to phono inputs) to the Power amp and connect a grounding wire between the Amp chassis and the AVR's chassis using the phono grounding post. This creates an alternative signal ground path which is secured by the grounding posts' screws on both ends. However, this requires modification to the power amps which voids its warranty.
2. Connect a grounding wire from the AC main' earth prong to the AVR's phono grounding posts. Because the power amp is already grounded to search using the included 3-prong power cord, this will also create an alternative signal ground path in case the RCA becomes loose.
Of course, one of the above methods could potentially cause ground loop hum.
The third option, which isn't applicable, is to switch to XLR balanced connection, but these are not supported by the AVR.
Which option do you think is best and safest?
Thanks.
Thanks.
