Best way to integrate Dirac without compromises?
J
joshz
Yeah i know that MQA isn‘t the real deal, real shame Tidal doesn‘t support uncompressed HiRes. Well in that case i would just go for the SHD and an amp i guess
J
joshz
Ok wow i just saw that Volumio requires a Premium Subscription to use Tidal Connect -.-
J
joshz
I would pass on MQA but paying for another subscription to use my other subscription.. that‘s a no.. looks like the M33 is the only do-it-all device
Gga
@joshz could you please mention the flaws of minidsp 2x4 hd that you mentioned before please? I am thinking of buying either this or flex.
Thank you.
J
joshz
I‘m just referring to the measurements in the review. If you have a top dac and amp this will just be a „weak link“ i think
pogo
NAD C389/399/3050 with Dirac Live/BluOS module are alternatives.
Dirac Live processing in the M33 is at 192kHz: Link
And this happens very rarely ;)
Trondi
M33 seems to be processing mqa with and without Dirac Live switched on. You won‘t be disappointed with the m33 methinks!
Axo1989
Sydney
Interesting in context of previous discussion of EQ and MQA. Also, nice review with comprehensive measurements.
antcollinet
UK/Cheshire
You post said "your PC" also, I expect "we were talking about" is subject to words actually written and reasonable interpretations thereof. :)
The quote he was replying to made it pretty clear to me.
antcollinet
UK/Cheshire
Isnt it better at this stage to inform OP a little about MQA?
MQA:
Is not lossless,
Is not bit perfect
Does nothing useful in the audible band
Throws a load of noise into the higher (ultrasonic) frequency bands.
best solution to your problem is to remove the requirement for MQA.
voodooless
Netherlands
MQA:
Is not lossless,
Is not bit perfect
You forgot about the bit where MQA is defunct ;)
antcollinet
UK/Cheshire
Holy necromancy, Tony. :)
Ah no. Thread had already been necromanced before my post. Necromancy cant re-happen until the thread has died again. :p
admittedly the post i replied to was a little old. But i wouldnt have even seen it without the prior necromancer. :facepalm:
Axo1989
Sydney
True, it was in fact re-animated !! :eek:
