In this sound system, Sony shoved the entire amp for the whole setup inside the subwoofer cabinet, and it powers both the subwoofer and the passive soundbar speakers.
There's a wooden panel below the amp where it sits on, which appears to separate the electronics area from the main subwoofer chamber.
Inside the amp chamber:
• The hottest parts are the long vertical amplifier heatsink on the left and the row of output inductors next to it.
• The cabinet only has tiny vent holes on the back (right).
• The left side (where most of the heat is generated) has no vents.
I'm trying to add active cooling with a strong fan to extend the life of the amp.
Questions:
1. What is that rectangular plastic thing likely for if it's not for wires to come through?
2. Would drilling ventilation holes on the top panel of the cabinet (directly above the amp chamber) affect the subwoofer acoustics?
3. What would be the best airflow setup for cooling this amp?
Questions:
