Best way to connect AVR and DAC to power amp without having to reconnect the cables?
anphex
Berlin, Germany
Hi guys,
yeah, pretty much thread title.
I have an AVR for all my purposes but I am thinking about getting a dedicated USB DAC for music. The only problem is I don't know how to wire this setup without having to reconnect the cables the whole time.
Is there a way to connect two audio devices to a single power amp?
D
Deleted member 46664
Guest
Well yes there is ... but you should check your AVR... many have pass-through inputs that can pass the DAC's signal to the power amp.
AdamG
Moderator
Reality
Just use rca connect cable to one of your free inputs like CD/Tape/DVD just don’t use Turntable/phono input. Should be easy or you can use an open Digital Jack or Optical in. If you tell us what AVR make and model you have, we can give you more specific advice.
SKBubba
So it sounds like you have the AVR preouts going to the amp? And you want to be able to play the dac out to the amp while bypassing all the AVR processing?
If so, hook the dac's analog out to the avr cd, aux, or similar input as mentioned above. For playback, select cd/aux/whatever as the input, and select the avr "direct" or "pure" or similar mode that bypasses all avr processing.
anphex
anphex
Berlin, Germany
Okay, I should have been more specific from the start.
My current setup:
PC->HDMI->Denon X3700->HDMI->TV
PC->HDMI->Denon X3700->RCA->Power Amp
My target setup:
PC->USB->DAC-------------> RCA->Power Amp
So I want the RCA cable to stay in the power amp but also keep it connected to the AVR but also to the DAC. Basically like a Y-cable.
SKBubba
My current setup:
My target setup:
Do what I suggested above using direct mode and it will be essentially that. You are bypassing the avr dacs and sending the signal directly (almost?) to the power amp using the avr as a preamp..
HarmonicTHD
My current setup:
My target setup:
Plenty of RCA Switches on Amazon etc.
Just make sure you are not disappointed not hearing a difference btw the X3700 (ca 100dB SINAD in pre-amp mode) and an external DAC. Plus you will „loose“ the Audyssey room EQ if you bypass the X3700, which will most likely effect SQ negatively.
D
Guest
My current setup:
My target setup:
Can't do that.
The rule is that you can feed multiple inputs from one output
But you cannot feed one input from multiple outputs.
It can actually damage your equipment.
Best bet ...
PC -> USB -> DAC -> RCA ->Denon X3700 -> RCA-> Power Amp
Just use a spare input on the AVR... let it do the switching for you.
Before you spend money ...
What's wrong with the DAC in the Denon?
Are you sure that an external DAC will be better?
AudiOhm
London, Ontario, Canada
Don't tell half the story, what DAC?
Ohms
SKBubba
This. I use pc usb out to a topping d10, but only for converting pc usb to coax s/pdif to feed X3600 dacs. I don’t use direct mode because you lose audyssey room correction, sub/bass management (no sub at all in direct mode), and dynamic eq which I love.
I played around with analog out from dac to analog in on the denon, and didn't hear much if any difference (guess the denon has pretty good adc's too). Didn't see the point of doing double conversion, so using s/pdif gives me digital all the way to the amp and speaker terminals, and all the cool dsp you can do on the way. Sounds good in my setup.
anphex
anphex
Berlin, Germany
As you all already say, using a high quality DAC like Topping/Gustard and then routing it through the AVR does make little sense.
I wanted to use the DAC with FIR room correction created in REW and then apply a loudness curve. So I get most of the benefits of a high quality DAC and (manual) room correction.
A passive RCA switch looks like the best bet so far, though I still have to get up from the couch to change the routing haha.
Zek
Where will you control the volume - via DAC?
Which DAC?
anphex
anphex
Berlin, Germany
Probably a Topping model with Bluetooth.
