Best Ti3255 Amplifier >>>Aiyima? Fosi Audio? O-Noorus?
Actually, I meant this post.
There were also some 2-tone IMD measurements by the same poster, but apparently not here but maybe on diyaudio?
Is such an adjustable power supply recommended for an amplifier with TPA3255 Chip?
I’ve been reading PFFB reviews for a while and am guessing that this feature causes the amp to run hotter.
Maybe this is why manufacturers avoided it.
80% efficiency is absymal. I ordered a similar aluminum case power supply (without the display) from Aliexpress and returned it, simply because efficiency at 50% load was 81% and the fan was noisy and kept running all the time, even in idle. The efficiency was not even specified in that case.
What purpose does the display serve anyway? Btw, this case seems to be steel. Nothing wrong with it if you don't run the loudspeaker output cables near it, but it shows all the budget went into the display.
This is just one example of a controllable power supply unit.
I assume the display shows Volt and Ampere
Anyone else thinking these external power supplies places in a fancy enclosure that matches the amp would be a nice touch? The audiophile world loves a separate power supply but only if it is £3k and comes in its own chassis...
As I understand the soecs of the TPA 3255 chip the PFFB feature is a standard on the chip. Please coorect if I am wrong. I think Fosi didn’t have that as a priority in the marketing of the ZA 3. Let us say it is a feature you can activate then it would be clearly described in the TPA 3255 application notes. If you go mono do get the the 48v/10a bricks so you don’t run out of steam.
PFFB is not a feature of the chip at all. It's a feature of the circuit it is used in. TI provide an app note SLAA788A with guidance on how to ensure amp stability with PFFB for the TPA324x and TPA325x chip amps, with example component values and calculations to apply it to their evaluation modules. TI apply the feedback around the chip amp only, but it seems some manufacturers have taken it back to the opamp input, making a compound amp a bit like Neurochrome does to improve on the raw LM3886 performance.
Don't waste your money on such power supplies.
I recommend high-quality power supplies, e.g. from Mean Well from the HRP N or N3 series. These power supplies are ideal for such amplifiers, as they can briefly (for 5 seconds) deliver 2.5 or 3.5 times the power. So with a perfectly adequate 300 watt power supply, around 1000 watts for 5 seconds.
In another thread wrote
You've missed the point that the TPA3255 has 4 single ended amplifier channels. Nearly all stereo amplifier implementations use these as two bridge tied pairs. They are then not able to be operated with a further BTL mode using the two pairs bridge tied again - doesn't work, will break the amp.
Then what are the advantages of the mono designs, like Fosi V3 or Aiyima A70 Mono?
There is another mode for the TPA325x, Parallel Bridge Tied Load (PBTL), that can be used if you need to drive unusually low impedance loads like 2 Ohm. Most of the mono amps use this mode, while a few of the stereo amps use one TPA325x per channel in this mode. PBTL is only an advantage if you have an unusually low impedance speaker. A mono amp may be useful if you need to drive a passive sub, or have a long distance between player and speakers, and want to put an amp close to each speaker to keep speaker cables short. On paper there's probably a crosstalk advantage too, but in practice the stereo ones have crosstalk low enough that you wouldn't hear it in most situations.
So, is the O-Noorus D1 the best TPA3255 amplifier?
I don't know, because I only know two other models from my own experience, but it's certainly not the worst and has the PFFB circuit implemented.
The choice of TPA3255s with PFFB has expanded recently and I wavered between the Aiyima A70 or the Fosi V3 monos, but then decided in favor of the O-Noorus D1 because it has a remote control and display and the internal components don't seem any worse than those of its rivals.
The display color can also be customized, which is also a nice feature.
I ordered directly from O-Noorus.
The price for the complete package including power supply was 99 USD, which was the equivalent of around 95 euros in Germany. There was no customs duty.
As the FiiO BTA30 is currently more or less standing around here, I'm using it as a DAC to accept the optical signals from the WiiM mini, whose own DAC isn't particularly good.
The D1 replaces the small and, in my opinion, very good Nobsound Bluetooth amplifier with TPA3116 in my study.
Impressions of the O-Noorus D1 >>> Clean workmanship, not much bigger than the TPA3116 amplifier, so quite small. (footprint 170 mm x 120 mm)
The connections are functional and of standard quality.
It's nice that the FiiO and the O-Noorus are both 120mm wide and also similar in height.
I think that fits very well visually.
The D1 is therefore paired with the WiiM mini, which feeds the FiiO BTA30 with the AK 4490, which acts as a DAC, via an optical connection. From there it goes on to the small Elac BS 203 Anniversary with the in-house JET tweeter based on the Oskar Heil AMT principle.
The power supply unit supplied has 36V at 5A, which results in a total output of 180 watts. In purely mathematical terms, a maximum of 90 watts can be output on each channel, which is perfectly fine for me and the small Elac. So far, the power supply has remained cool even under high load or at high volume and does not emit any background noise. I doubt whether a more powerful power supply unit necessarily leads to a better sound, as I have already experienced the opposite.
I won't torture you again here on ASR with my subjective sound impressions, but I am very satisfied with the D1.
The O-Noorus D1 convinces me as a very inexpensive and powerful TPA3255 amplifier with PFFB implementation with a transparent sound image. Clear highs, natural mids and a tight bass foundation make for a satisfying listening experience. In my opinion, its transparency and spatiality also make it a good choice for more demanding listeners.
If you are looking for a compact, very inexpensive but (with the right power supply) powerful amplifier which, to my great delight, can also be operated remotely and has a display, you should give the O-Noorus D1 a listen.
The heat development remains moderate and has not caused any problems so far, which may be different with a larger power supply unit.
For me, I consider the TPA3255 experiment to be successfully completed for the first time.
I don't know whether I'll be buying any more amplifiers, because I'm actually already completely oversupplied, but I was just curious about such a small TPA3255 amplifier.
I can't imagine that the TP3255 PFFB designs differ too much in terms of sound, because the circuit designs around the actual chip are now tried and tested and largely exhausted, and some of the components are the same or at least very similar.
But Amir can and probably will measure this sufficiently.
PS
@Alexander Lin
The color assignment of the cinch connections should be changed, because it does not correspond to the standards and is a little confusing at first.
I could imagine that some people only pay attention to the colors and not to the labeling, so that they connect the right channel to the red subwoofer connection.
In my opinion, it would be better to label the stereo speaker pair in RCA red and white and the subwoofer in yellow or another color.
It should be noted that devices that have not yet been tested by Amir have a difficult time.
The number of posts and contributions from new owners in this forum regularly skyrockets as soon as a device has achieved a good result, as was the case with the Fosi V3 monos or the 3e TPA325x amplifiers, for example.
It is probably advisable for any company that wants to significantly increase its sales figures to send a device directly to Amir for testing rather than waiting for private individuals to take it over.
Alexander LIN had done it with O-NOORUS D1 and D4 :)
What about the D3 Pro? Wasn't that supposed to be out for Chinese New Year?
It was supposed to come out this month but there were a lot of suggestions and requests about it, maybe they are still working on implementation. Its not released on the site yet.
Hello @ICIETDIYEUR ,
didn't your signature once say: O-Noorus D1 with modifications?
What happened? Smoked out because of modifications? ;-)
