I have seen that. However it seems that overall volume distortion is a concern. I want to find a pair of speakers that could eventually fill a good sized roomWelcome to ASR!
Check this...
That’s the tower you recommend? The Polk r700 ? No to arendal speakers? Or revel?A big room and acoustic treatment, chasing ISO 3382-1. If you want loud HiFi tire isn't where you should be looking but uper part of Pro segment with measurement (from manufacturer or elsewhere).
If you are not into braking SPL of over 102 dB especially in highs (which HiFi can't do with little tweeters) you should focus on mid bass performance and pair of good sub's. For example Polk R700 + 2x 12" sub's. So that you get lower THD where it matters the most and where true peeks will be and nice capable enough midrange clear from cabinet and other harmonic influences (separate driver preferable in it's own enclosure over 5.5").
Think those would sound good with a Wiim amp ultra and a Willsenton R8?The answer for me was Klipsch Heresy IVs. Only $3500 for the pair including tax. Perfect for my main setup in my living room. Slight toe-in. I found when I moved them close to the wall that I didn't even need the subwoofer I had. Wide soundstage. "Live" sound like the musicians are in my room. With Fosi V3 mono amps, they will easily go way louder than I would ever want.
Edited to add: If I had a larger room, I would have gone with the Forte IVs or Cornwalls. Both of those would put you over $4k.
I would really, really go over 10" sub's, ported 12" one's at least (or bigger close enclosure one's so that you don't compromise much regarding time domain).That’s the tower you recommend? The Polk r700 ? No to arendal speakers? Or revel?
Would one RSL speedwoofer be good enough?
I do need it for a large room now, but it’d be nice to only invest once and the speakers be able to fill a larger room once I upsize
Those better than super lintons?How big is the room? How loud?
I was looking at these myself, but hesitant to move on from Energy C5s and C9s.
March Audio Sointuva AWG: https://www.erinsaudiocorner.com/loudspeakers/march_sointuva_awg/
On sale for $4k
The important localization and soundstage information is the responsibility of the recording engineer, not the loudspeaker.
Soundstage and imaging is determined by recordings.
I enjoy upmixed stereo for many, but not all, programs... Switching back to stereo results in a diminished sense of envelopment and a shrinking of the soundstage.
I love my Sointuva AWG speakers. Everytime I turn my system on and sit down to listen to music I am impressed by its bass, power handling, clarity, balance and soundstage. And it's been several months now since I have owned then, honeymoon phase should have been over, but still going strong.How big is the room? How loud?
On sale for $4k
You have to decide for yourself, as there are diminishing returns. Check Erin's Parting / Random Thoughts. One note: if you want to play it LOUD, the measurements for the March Sointuva AWG assert that it will do so - if given proper amplification - with almost zero compression (if you have subwoofers to help at 50hz). But again, will differences really be audible for you, and will it be worth the step up in pricing tier?Those better than super lintons?
I guess which ever one is more compatible with a Wiim amp ultra and a Willsenton R8You have to decide for yourself, as there are diminishing returns. Check Erin's Parting / Random Thoughts. One note: if you want to play it LOUD, the measurements for the March Sointuva AWG assert that it will do so - if given proper amplification - with almost zero compression (if you have subwoofers to help at 50hz). But again, will differences really be audible for you, and will it be worth the step up in pricing tier?
Easily compare loudspeakers measurements
www.spinorama.org
sound stage and quality under 4k?
