That 300Hz hard limit is the thing I'm not ready to accept. If you agree with the stuff Mitch posted which basically states that room gently transform it's behaviour from modes to diffusion than one would expect that if we perceive room EQ in the 20-300Hz region than in the next region we would partially perceive it while later we won't perceive it at all. In other words, I would expect our perception of room EQ effects to gradually fade instead of being brutally switched off at 300Hz.
I totally agree there is no hard limit and that there's a transition region.
My main argument is that, at say 600Hz, the distance between the peak of a room mode and its null will be around 30cm.
If you use EQ to knock down the peak of that mode, this can only possibly be valid over a listening position range of less than 30cm.
30cm from the listening position, your room correction is going to have the opposite effect to that intended.
TBH, given that, I can't see what else there is to discuss
IIUC, you're saying that in your room you measured peaks in the midrange that, even when averaged across a large number of different positions in the room, including positions well away from anywhere you normally listen, were clearly still present. I know you know what you're doing when it comes to MMS measurements.
My hypothesis is that perhaps what you've measured is a nonlinearity in the speaker itself. Of course that's only speculative. But a 600Hz mode will have around 16 peaks and
16 nulls just across one length of a room of 4m.
Given that, my two questions for you are:
(1) If what you've measured at 600Hz
is a mode, is changing the (let's assume for argument's sake) already-linear response of the speaker a good idea given the mode's peaks and dips are closer together than your normal head movements are likely to be when listening?
(2) If the peak you've measured is
not a mode
and not a speaker nonlinearity, what is it?
And assuming you have an idea of an answer to (2), why then should it be corrected?
