Best portable CD player or audio device for in-car use
LynnTunes
I would love all your help here. I am looking for the best for-car solution to play CDs or possibly an alternative option (not phone).
1. First choice is a portable CD Player but my car (Toyota Crown Signia 2025) has no audio / aux input, which means I’d need to use Bluetooth.
2. I do not want to load my music on my phone. This is not an option.
3. I’ve read several of @NTTY reviews and eliminated the Fiio dm15 because it didn’t perform as well as it was marketed to perform. Neither the Fosi Merak nor the SMSL 150 / 100Pro have Bluetooth.
4. Last option is ripping CDs to some kind of Bluetooth device that is not my phone.
What is my best option?
Is there a portable CD player that would work?
If not, what does the community recommend?
The bad news:
Barely anyone does objective tests of portable, battery-powered CD players with Bluetooth output.
The good news:
-There are not that many options from what I can tell
  • Syitren R300
  • KLIM Nomad
  • HOTT CD611T
  • Oakcastle CD100
  • FiiO DM13/DM15/DM15 R2R
  • Shanling EC Play
-most of them are not expensive
-you can test their performance yourself with a Berrybak BEA1 and Hifime UR23.
Simply play any CD that you own with the CD player connected to the BEA1 and record its output with the UR23, then compare the recording to a rip of the same CD made with Exact Audio Copy, using https://deltaw.org/.
Alternatively, you can of course rip all of your CDs and put them on a DAP for playback in the car. There are even some that keep the CD aesthetic like the FiiO Disc :D
Welcome to ASR,
@staticV3 offers useful suggestions.
Consider securing your choice to the interior of the Toyota and reduce the risk of a portable Compact Disc player becoming a 'flying saucer'. :)
The bad news:
The good news:
  • Syitren R300
  • KLIM Nomad
  • HOTT CD611T
  • Oakcastle CD100
  • Shanling EC Play
I did not know the BerryBack, thanks for the info.
I bought it and I’ll test the digital output from the BEA1 when fed by the Shanling EC Play. It will be SBC output so it should still be close to 16bits total resolution, I suppose.
Does your car have the ability to read music from USB stick - or other memory device?** Many do. If so this might be by far your best option.
EDIT : **Gemini thinks it does (I have not fact checked - Ill leave that to you since its relatively easy to put a few files on a USB stick and try it out.)
I have a Toyota Crown Signia 2025. Does the music system have the ability to read music files from USB stick or other memory device?
Yes, the Toyota Audio Multimedia system in the **2025 Toyota Crown Signia** can play audio files directly from a USB drive.
To play music from a flash drive without issue, keep these specifications in mind:
### 1. Port Location
* Use the **primary USB media port** located in the front center console.
* *Note:* Modern Toyotas feature multiple USB ports, but secondary ports are strictly for device charging. Look for the port designated for media data transfer (often the USB-A or main USB-C port near the front dash/console).
### 2. Supported Formats & Drive Setup
* **Format/File System:** The flash drive should be formatted in **FAT32** or **exFAT** (single partition).
* **Audio File Types:** The system natively supports standard audio files, including **MP3, WMA, AAC (m4a), WAV, and FLAC**.
### 3. Folder Navigation & Best Practices
* **Navigation:** On the 12.3-inch touchscreen, select **Audio / Media** as your source, then tap **USB**. You can browse by folders, artist, album, or track list.
* **Folder Limits:** For smooth indexing, organize music cleanly in basic subfolders (e.g., `Artist/Album/Songs.mp3`). Avoid excessively deep nested folder structures to prevent indexing delays.
* **Playlists:** Custom playlist files (like `.m3u` or `.pls`) are often not supported or indexed reliably, so grouping tracks into dedicated folders works best for organization.
You can use any portable CD player that works in your car.
There are plenty of Bluetooth transmitters/transceivers available—either battery-powered or with a 12V input—that work with any CD player featuring an AUX or headphone output. I used one myself, and it worked perfectly; back then, the battery-powered version cost around €10 on Amazon.
If you play from a device over BT as used in a car, there's no point in trying any files better than MP3s.
If you cannot use your phone, you can buy my iPod Touch 64G for £60 - it's on FB mktplace in the UK..
If, as someone suggested, you can plug an SD card into a slot in the radio, then do that. Chances are your radio will be good for up to 1TB cards and the unit may even play FLACs from it (albeit possibly overkill in a car). My car is a fabulous Skoda Citigo, and I plug a 512GB card into it, and that holds enough music for a trip from Land's End to John O'Groats and back several times. And more. I have a dead simple system to synchronize it with a subset of files and all the 120+ playlists (without alteration) on my NAS or PC, and it's the same for microSD card in my phone...
Point is, forget the CD nonsense for use in a car - that idea went 20-30 years ago.
Thank you! I don’t think my car has an SD slot, but I’ll check. I’m coming around to the idea that finding a way to carry my music on some kind of audio device or your idea of an sd card is probably the best way to go. I can start by copying my favorite music and add as I have time.
There is no USB input in the car. I have a little converter that can take usb for charging and maybe could run an iPod. When I checked AI results, it said none of the USB ports are audio inputs. I can play stuff via Bluetooth easily by connecting a Bluetooth device to my car stereo.
Seems the best route is going to be that one. Now I have to figure out a quality player and rip all my music to it, which sounds like countless hours of ripping. Boooo…
Then go with bluetooth. There can be no possible audible disadvantage in the noisy environment of a car.
For drive accuracy, you can use AccurateRip's drive statistics: https://forum.dbpoweramp.com/forum/dbpoweramp/cd-ripper/337997-cd-drive-accuracy-2026
Btw, did you give up on the portable CD player?
FWIW - As someone who has ripped a massive CD collection (mostly using fre:ac), I have never had a single bit discrepancy (at least according to online databases, and where the CD is known), except where a CD was damaged and unreadable in part in any of my CD players. Ripping was largely done on a PC with a CD unit, then on a laptop with built-in CD unit, and more recently using one the cheapest USB CD/DVD reader/burners you can buy on Amazon (they usually have the old but perfectly good Mitsumi mechanism). I used to rip with "paranoid mode" set but eventually realized it was not needed.
2026 Crown Signia XLE owner here. As mentioned in an earlier post, the (sole) USB data input port is located inside the center console (USB type C port), toward the front of the box. Can confirm it will play mp3 & wav audio files and be recognized as an audio source by the stock Toyota infotainment system. I invested in a USB splitter with manual switches to accommodate multiple data sticks. The Signia will only recognize one USB data input stick at a time. The many other USB ports in the vehicle are for charging only.
I recently bought a Nomad Klim portable cd player (thank you for your earlier portable cd suggestions, staticV3!) with bluetooth (the one with the faux wood surface) off Amazon. Connecting it via bluetooth works, but it's far more kludgy and unsafe to access while driving than an old-school built-in dash cd player. For the moment, I'm velcroing it in place inside the driver's side door pocket with the power button facing up. Other than not being able to take out or load a cd very safely while driving, the door pocket location is working out ok for me. The cd player's other audio controls can be managed via the car's own audio related buttons and volume knob. (To get it connected, I had to add it as a secondary bluetooth device via the car's settings menu and enabled audio). That said, I'm still looking for a better way of securing the portable cd player in a fashion that better balances safety and access concerns. I use the player mainly to play audio book cds I borrow from my local library.
The Shanling EC Mini has a front-loading design which should be safer to operate in a vehicle. Definitely not cheap though.
It's shocking that a 2025 Toyota would not have USB audio input.
Oh it does.
From experience let me add that car audio systems can fail to read larger-capacity USB flash drives. I suggest you use a flash drive no greater than 64GB.
Yes.
Oh it does.
Yes.
Bare in mind, the info in my post was from AI. As I pointed out, it might get specifics wrong - which is why I set OP should test it himself. Which he did.
Bear in mind I wasn't relying on your forum post alone, there's more authoritative information on the Toyota Crown forum -
https://www.crownforums.com/threads/usb-drive-music.113/
Can the Crown Signia 2025 model be that different to the 2026 model such that USB audio playback is missing?
@LynnTunes do you possibly have a manual for your car's multimedia system? Surely there would be some information there?
The usb was my first thought. I searched your car and audio and didn't get a lot then added usb and it suggested a usb cd player :) It does have usb ports, tho?
Back in the day I used to use Sony discmans.....been a long time since I haven't had a cd player in a vehicle (and my current cd player head unit has usb input).
LynnTunes' 2025 model Crown Signia certainly has USB ports, and Jazzbo's 2026 model Crown Signia is reported to support USB audio.
It cannot be any USB CD player, because the Toyota Audio Multimedia system runs on a custom operating system. The CD player I mentioned in post #18 is specifically advertised to work with the Toyota Crown Signia.
