Can you give some info on how good the Qobuz integration is? For example does it integrate well with Qobuz playlists?
Good question.The Qobuz integration is generally good and complete : favorites tracks, albums, artists, suggestions from Qobuz and specialist magazines, etc. For the playlist, I'm quite sure but I'm out for few days and the Volumio app doesn't work without connection to the Volumio streamer [I'll check when I'll be back, send me a MP if I forget]. The UI is nice and good but a bit weird (for example, to navigate into previous tasks or menu you have to click on a dedicated button and not use the general "previous" button of your OS phone).
For my personnal taste, I prefer the native Qobuz app for its UI and due to my habits, but it is not userfriendly at all when not used through bluetooth or with a non "Qobuz direct" compliant device...
LMS (and hence PiCorePlayer) does have a Qobuz plugin, and its forum thread suggests it is still working and supported.Finally, I believe that BubbleUPnP Server may be the only completely free method of accessing Qobuz from a Pi-based streamer, in other words without subscribing to a paid service like Roon or MyVolumio. (Perhaps it can be done with PiCorePlayer? I’m prepared to be corrected on this!) Last a November Qobuz revoked the API credentials of Kodi and perhaps others based on a security concern, according to issues posted in Github, so that’s no longer an option.
No, it's not the only way. I use upmpdcli with a regular DLNA server and a player running mpd. I can then play Qobuz using the BubbleUPNP Android app.Finally, I believe that BubbleUPnP Server may be the only completely free method of accessing Qobuz from a Pi-based streamer, in other words without subscribing to a paid service like Roon or MyVolumio.
Has anyone tried the Tidal or Qobuz support in PiCorePlayer/LMS? I know LMS has plugins for them, but have no idea how good or bad the integration is, either from the perspective of the normal LMS interface or the Tidal/Qobuz apps. As I understand it the Tidal one also requires a free mysqueezebox.com account.
I came from Volumio, been using Ropieee on my RP4’s for a while now as Roon endpoints with Tidal and won’t look back. Works sooo well it’s not funny.
ConversDigital's mconnect Player app can be used to control any standard UPnP/DLNA supporting streamer (so includes RPi ones), as well as Chromecast devices, to stream audio file tracks from directly from both TIDAL's & Qobuz's respective online servers.
The BubbleUPnP app is my preference on Android, but unlike the mconnect Player app I mentioned, there's no version for iOS and it cannot provide TIDAL's hi-res MQA masters tracks - for those that must have them.Needless to say, you can easily play back TIDAL & Qobuz streams directly from BubbleUPnP app as well, it's just a different GUI from the native TIDAL & Qobuz apps.
Roon also support dsp with impulse response.I am presently using Volumio on a Raspberry Pi 4 to stream Tidal and it sucks!!!! But one feature Volumio has which I love is the Brutefir plugin for digital room correction (not a parametric or graphic equalizer). The Tidal inter phase is being re-written and I am willing to suffer until it is fixed. Are there any other o/s servers which offer digital room correction as a plug in?
