Best mics for board meetings
DEvans3906
Hi all, not sure if i'm posting in the correct thread or not. But looking to see if anyone on here does set ups for Board Meetings. We bought a wireless 8 mic (XTUGA YT8 off amazaon). They worked great a few times, now they hardly connect. We bought another system, same thing, a third system, same results. They'll work good the first 2-3 meetings then they just have a hard time connecting to the receiver, get static, or just not produce any sound at all, etc. Does anyone have a 8-10 wireless microphone system you prefer, recommend. The Board likes the Wirless so going back to wired is probably a no go.
If you're running between 8 and 10 wireless mics and expect decent reception and audio quality you'll need to get a professional wireless system from a reputable company like Shure Audio and will be costly. I previously worked in the professional A/V industry and wireless needs a lot of finesse and understanding. Even with high-end pro gear it can be frustrating. Firstly, each mic needs to run on it's own separate RF frequency which needs to be clear of other signals that will cause interference (working in major cities made this a nightmare). How many channels are available on the system you bought? With 8 mics you need at least 8, preferably a lot more. Secondly the distance between the transmitters and receivers needs to be kept as minimal as possible and line-of-sight. Proper orientation of the receiving antenna(s) is also crucial.
Check the mic for a backdoor to the Internet such that your competitor or the Chinese government can listen.
And consider that they're probably just FM based devices, so anyone nearby with a cheap scanner or SDR can listen in.
I'd second how effective a professional system can be. We use a Shure Intellimix system in our boardroom and it is extraordinary how it can filter extraneous noise and pick up even the softest spoken participant. I would add though, we recently had some issues with it and Shure's customer support was appalling. Not what you expect at the price we paid.
My company uses Owl cameras which have mics built in, but if you're looking for individual desk mics I agree you should be looking at Shure.
If I'm reading the Amazon description correctly, that is a UHF system with multiple channels (120) rather than a Bluetooth system. You may need to resync/re-pair each transmitter to the base station each time they are turned on and off. That might account for the symptoms you are hearing.
@Radiomic has a good point, at that price, it is probably FM modulation which is easily intercepted. And I would agree with other commenters, that the Shure system is the most secure, but expensive. It uses AES encryption.
If your work involves a lot of radios, small radio spectrum analyzers like the TinySA are inexpensive.
Are you certain that you are operating the wireless part of the system correctly? Using wireless audio gear takes a decent understanding of how wireless systems work and the vast majority of problems with them are due to user error.
