Best IEMs/Headphones for Acoustic Drum Playing?
mj30250
Greetings. I'm seeking recommendations for a suitable means to protect my hearing during acoustic drumming at home.
Goals:
I want to hear as much of the drum kit as possible - tone, attack, sustain, resonance, texture, etc - all while protecting my ears to a reasonable degree. Simple passive ear muffs like what you might use while mowing the lawn can work okay, but that doesn't help much with the next goal.
I need to play music tracks through them that I will drum along with, so accuracy/transparency are important. A slight bass boost would be welcome, but not something that's bass shy.
My source will be a cell phone (Android), so I would simply use an appropriate USB-C adapter with inline DAC.
I would prefer to keep to a budget of $200 or less (I could possibly push a bit further for a clear and worthwhile performance gain), but if a $40 pair of IEMs would check the boxes, all the better.
Thanks in advance.
Truthear Hexa has a neutral tuning, suitable for playalong+monitor, and knowles dampers that are more resilient than pourous filters that some other IEMs use and will probably clog prematurely in your setup.
I haven't heard the Truthear Hexa but after reading a couple of positive posts on the KZ-ZVX Pro, decided to give it a try and have enjoyed them. They have a balanced sound (to me) with a bass lift that provides extra punch and definition, a good midrange and good treble. There is a slight rise in the treble region that can be a little brighter sometimes (if an instrument excites that area) but I don't really find it too objectionable. Probably my old ears need an little boost in that region. At any rate, for $25 at amazon or half that price through the Alibaba connection, I've been using them for music listening and electronic drums rehearsal through the Pearl Mimic Pro. I'd give them a go through Amazon first to see if you like them and return them it not. I'd also listen to some high quality music tracks to see if they tick your fancy. There's four or five reviews of them on the Head-Fi website and others. Hard to believe the quality that's available these days for so little. On a side note, they aren't going to save your hearing unless you have some type of limiter on your phone.
Goals:
Thanks in advance.
IEM - https://hangout.audio/products/crinear-daybreak?variant=42226242846768
Dongle DAC/Amp - https://hangout.audio/products/jcally-x-crinacle-ap6?variant=42558363402288
But Hexa is not a neutral tuning at all
My budget pick would be the GK Kunten. It's the new hot thing and something of a market disruptor atm. Love the sound of drums and percussion on them, transient response is very good, as well as thumpiness in the bass. They've put all my cheaper sets to shame, including the Zero 2, Zero Red, KZ ZAR, ISN H20, Tangzu Xuan Nv... Like the Kunten better, great clarity and definition across the spectrum.
