- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,406
Would steer clear of PMC and ATC personally.
KH310. About the Dynaudio, you should worry a lot, since they give measurement data for their cheaper LYD serie, but strangely omit it for their flagship. Lack of waveguide should also be a red flag for anyone.Ok peeps, now I need advice on a "B" set to my Genelec 8351B pair. I will make is simple for you since it is multiple choice. Which set will be the most "complimentary" to the Genelec's?
Choices are:
Of course I am open to other options, but these are the ones that will fit the best in my space next to the Genelec's.
- Neumann KH 310
- Neumann KH 120
- Dynaudio Core 47
- Focal Solo6 Be
- Focal Twin6 Be
Thanks!
How could you call this horizontal directivity "not terribly wrong"?I would say nothing terribly wrong but.... meh
Let's throw another speaker in the ring. How about PSI Audio?
Perhaps I missed it(haven't read the full thread), but I don't think people are saying tweeter material doesn't matter. I think what they're saying is that tweeter material doesn't matter if all other things are held constant; that is, they measure the same in every way(at least within the audible range).
Think they use Pascal Class D. If you are worried about that the Kii Three's are a better option. But those are even more expensive.Well ... There is the Dutch and Dutch 8 Studio at around U$ 8500. Not sure if the application is near filed but this speaker seems to be the complete package. Flat, truly full range and superb horizontal directivity... A bit over budget but does Not need a subwoofer
On paper, the Kii are not a better option.Think they use Pascal Class D. If you are worried about that the Kii Three's are a better option. But those are even more expensive.
Here's the measurements of HR824mk1.
Note: Current is Gen 2, called HR824mk2.
I too worry about the future of D&D. I would hate to spend that kind of money on a loudspeaker only to have the company disappear on me.I would still go with a pro audio company only, who know if d&d would exist in 5 years, how reliable is the 8c etc
I have posted about this...I too worry about the future of D&D. I would hate to spend that kind of money on a loudspeaker only to have the company disappear on me.
I am not knocking their products or vision. Nonetheless it’s a concern. Their financial stability as a company is unknown. In the grand scheme of things they are an infant.I have posted about this...
If such were the general population mindset ... we would be having this discussion on a text-only bulletin board, using MS-DOS on an IBM PC ...
You have made excellent points about what will be "different", but what would be your advice on what would be a "better" speaker even if it is similar to the Genelec's?
You may need to read a bit about the Dutch and Dutch 8C.. It actually uses the wall.. In the back of each speakers there are two 8 inches subwoofers drivers operating from 100 Hz down. The 8C, use the wall for controlled bass reinforcement , you must set-up some parameters based on the distance from the wall ... With that it achieves performance that are close to incredible.. Mitcho managed 20 to 20,000 Hz plus or minus 3 dB while being phase coherent... with apologies if that this is not llowed, from Computer Audiophile here is this speaker in-room.Since Kii and 8C have been mentioned, it should be worth pointing out that their cardioid radiation pattern means that even if their on-axis measurements (or perhaps even 30-deg off axis) are same as other speakers, their in-room result is going to be different, due to lack of backward energy = lack of extra boost from rear wall reflection, for better or for worse. Theoretically, it should be better. Frequency response can be fixed with EQ, reflections can't, unless you're using FIR filters.
