And how would I send the signal back to the Yamaha to use the headphones?The option to insert a DSP or equalizer in between your tape connections will work for all your inputs.
I’ll try that.The line 2 tape out acts like a pre line level (w/o volume change ) that go into the DSP or equalizer that you use for your headphone listening (note DSP must have its own hp amp). The rca returns from the DSP then plug into the line 2 tape ins so that you can apply sound equalization via the power amp section to your speakers and room. You listen to the equalized sound by selecting tape on your integrated amp.
Check your manual to make sure your amp's tape input 2s work as I think they do. This is standard tape functions for most integrated amps-receivers. I assume you are not using your tape selector so it is free,I’ll try that.
So I hooked up my JDS Labs Element to the Tape (Line 2) outs, and put ran the RCA's back to the Line 2 ins. Listening to a CD (Balanced Input on the Yamaha), I could listen to my headphones on the JDS Labs, but when I switch the Yamaha to Line 2, I get nothing. I only hear sound when on the Balanced Input from the CD, not from the JDS Labs. I think the issue with the Yamaha is there is no Tape Monitor functionality. Yes, I can send audio out via the Line 2 outputs, but there is no way to listen to what is coming back from that output.Okay, so checking addo123's comment on the straight miniDSP HD, if your amplifier's headphone output allows you to select the tape out then you should be able to use your amp's built-in headphone amplifier. I am going to check the manual for your receiver.
I'm leaning towards getting another RME ADI-2 and outputting the MusicCast to it via Optical and my SACD to it via Coax, then feeding the RME back to the Yamaha via the balanced input. I'll have to forgo the equalizing the turntable, but 90% of my listening is via streaming or CD.
