I've got a Yamaha 2100 integrated amp and would like to get headphone eq setup but I'm not sure about the best product to use. Any suggestions that will allow me to continue to use the built-in headphone output?
And output to it how? The preout is being used for a sub.Given the high THD and the low output power, it might not be worth dealing with the inbuilt headamp - I'd get a separate headamp.
"Headphone Jack Rated Output Power / ヘッドホン定格出力(1 kHz, 32 ohms, 0.2 % THD)CD, etc.... 50mW + 50mW"
file:///tmp/mozilla_michael0/Yamaha-AS-2100-Service-Manual.pdf
I think you’re right. After reading a million times on this site how important it is to eq headphones, I came to believe I was missing something when it came to a traditional hifi setup. It seems everyone listens on computers (which I do at work), so any solution may create a myriad of other issues.Where is the chain could you put an EQ box? If you're not careful you are going to talk yourself into a multiple input pre amp, output to an EQ box then onto the Yamaha do do the heavy lifting.
I think I was hoping for a 1/4” headphone cable that could plug into the Yamaha and go into something like the RME ADI-2. Or maybe better if RME had a pre-amp built into something like the ADI-2 to give me that great eq functionality.
Maybe Yamaha will build a 2 channel AVR (since every AVR they make has built in parametric eq, like my 3700).
There's also the way of using a passive filter for eq'ing your phones - plugged-in at headphone out. Look on Solderdudes' site (DIY-Heaven), if there's a filter for your particular phones available.Any suggestions that will allow me to continue to use the built-in headphone output?
What all of these great options are lacking are enough/ different inputs. I’m currently using balanced out from my SACD player, RCA from both my turntable and MusicCast. The Schiit looks like it can only handle a single RCA input and the Behringer seems to be limited to one balanced and one digital input (which I could use for the MusicCast).One off-the-top-of-my-head, probably less than perfect suggestion: My Swiss Army knife for the past 15 or 20 years—can do EQ for headphones, and room EQ (though not like Dirac, etc., but it does have graphic EQ and parametric EQ), among many other things. . .
https://www.amazon.com/Behringer-Ultracurve-DEQ2496-Ultra-High-Precision/
Looks like it’s on sale for the moment. The things you can do with it are only limited by your imagination. It’s a little dated by now but I use it every single day.
@amirm ’s review: https://www.audiosciencereview.com/...nger-deq2496-ultracurve-pro-dsp-review.16991/
Whoops, no EQ. It’s predecessor did get a swinging panther, so probably a great preamp.
