Best desktop speakers?
I don't know much about Fyne Audio, but this post doesn't instill great confidence
I did not, and would NEVER recommend the speaker you are referring to.
Speakers I DO recommend cost 5x to 10x more than Fyne Audio F5E..
The speed, resolution and clairity of the low frequencies coming from F1-5 is beyond, all the way down to some 35hz... :)
I have the KEF R3 paired with Buckeye's 700W amp, I'm wondering where should I invest my money next? Are there any better passive speakers at hand? I already have room treatment so that is sorted out.
Curious what the community recommends as those speakers were bought several years ago and wondering what's new in the world of desktop speakers.
Specifically what are you trying to improve? OG KEF R3s are fine speakers already. The best thing you can do is choose a flavor of DRC and apply room correction to the bass. Or, at the very least, measure the response at your listening position and use REW to EQ the bass frequencies as much as possible. R3s take equalization very well, so you can mold them into almost anything with EQ throughout the FR.
A sub isn't a bad idea, but at desktop distance and levels, you can extend the low bass down to about 33Hz without inducing too much distortion.
These are plots of my R3s with Dirac applied up to 1KHz:
Not much to fix there unless you just want to spend money or want something the R3s can't do like wide dispersion.
only Genelecs small enough to be considered for desktop duty are the 8010A imo. i know it's personal, but i don't like my home office to look like a recording/mastering studio with big speakers right in front of me. smaller speakers also have a possible tiny advantage in accurate staging/timing when it comes to sitting immediately in front of them.
It certainly depends on the room size and the listening distance. I have 8331As wall-mounted (angled towards the listening position, approx. 30 cm depth, listening distance about 1-1,2m). The 8341A would also fit well, and even the 8351B should be fine at close range (e.g., if no additional subwoofer is to be used ...).
