I am looking for a new headset for PC gaming (first person shooters).
It should be closed back to keep outside noises out. I already have Sennheiser HD650 for music listening.
So far the best suggestions I could find is:
Beyerdynamic MMX 300 2nd gen [Thomann link]
32 ohm headphones with cardioid condenser mic (requires 1.5-9 V supply).
I suppose the frequency response is similar to DT770. Even though I usually prefer a more flat frequency response I guess it might be ok for gaming.
I guess most sound cards and usb dongles output something between 1.5-5 V as phantom power?
Beyerdynamic DT-290/M200/H250 MkII [Thomann link]
250 ohm headphones with hypercardioid dynamic mic
This is the same as DT250-250 with a dynamic mic.
The good thing about DT250 is it's okay flat frequency response.
There is another option with condenser mic that requires 48 V phantom power.
Do you think the dynamic mic is better for this purpose than the condenser?
At the moment I do not have a recording interface so I would need to get one to use phantom power.
In principle the hypercardiod mic has a back lobe that could pick up keyboard noise, but maybe the higher gain main lobe would compensate for that.
At the moment I am leaning towards getting DT-290/M200/H250 MkII with the mini-jack cable K190.48 and just use it with the apple usb-c dongle.
The headphones are high impedance, but quite sensitive so I guess the dongle should be enough to get them to normal listening volume.
Any thoughts/suggestions are appreciated
