Best cheap USB-C headphone dongles?
Have a look at my more advanced features on Pragmatic Audio => https://www.pragmaticaudio.com/head...K&F7=7200&Q7=1.1&G7=-4.8&T8=PK&F8=0&Q8=0&G8=0
I have a visualizer popup to visual and drag filters around to the shape you want and a few other advanced features. The main squig.link Cringraph codebase is a bit messy though - I developed the devicePEQ with a 'clear separation' as the Cringraph needs allot of work so I felt best to leave it alone.
I really like the advanced EQ features on your Squig site. Quick question, is there a way to tap into the secondary hardware gain on some of the nicer dongles? I tried your tool with the TRN Black Pearl and while the EQ pushing and pulling functionality works correctly, every time I push an EQ, the hardware volume drops by a lot. Judging by ear it sounds like 40dB or more of attenuation. I have to use the physical buttons to bring the volume back, which makes A/B'ing settings very hard. Did you run into that issue with other USB DACs?
So, I took a conservative approach to avoid clipping, so I apply a negative pregain if the PEQ filters have large positive values but some of the nicer devices actually have a hardware based pregain calculation. But I think I figured out the pattern to recognize which devices have it built into hardware and with ones don't so I can just apply my software versions to the ones that don't.
The next version will include this support so should supported the hardware specifics features of more of these dongles.
Reference audio analyzer recently uploaded a review of Jcally JM7 (non max), which is supposed to use CX31993 like Graveaudio DA06:
Results are very surprising, to say the least, it has a noise floor of a high end DAC such as CS43131, less than 1uV and extremely high signal/noise:
In fact, noise performance seems to be marginally better than JM20 which they also analyzed recently:
However, they also analyzed Graveaudio DA06 which also has CSX31993 and signal/noise was much lower and more in line with what other testers found about CX31993:
But, checking other tests of JM7 in their review, we can also see the typical weird jitter pattern in 12K test:
Indicating that it is indeed CX31993.
So what's going on here? does CX31993 JM7 variant use a different firmware with some sort of DRE that allows it to have very inflated snr and noise floor?
So I have tried Graveaudio DA06, a CX31993 dongle without additional opamp, and it's fairly good in use. No crackle in the referenceaudioanalyzer test:
Only very occasional crackling in the polarity test, but mostly clean, nothing like JA11 which is absolutely terrible (except with Tinhifi firmware, but that has terrible hissing and noise floor):
There is no hissing... after like 200ms of playing a silence video, slight hissing in first 200ms or so and very slight popping after. Most likely what is happening is the dac is applying noise reduction when it detects a very low signal level, like it was commented here:
Interestingly, similar thing happens with Jcally JM6 Pro, noise is higher first 200ms or so, it's just that the noise reduction that happens with that combo is nowhere near enough to eliminate hissing, it reduces hissing from extreme to very high, because MAX97220 introduces a lot of noise.
That being said, the power consumption this dac has is absolutely amazingly low, so all in all it's really good for the cost, you can get this thing for as low as 1$ depending on new account or not, but if not it's less than 5$.
After testing a bit, the popping after you pause a song or when the song ends is more annoying the more sensitive the iems are, so I've tried KZ EDX PRO 2 (107 db/mw sensitivity and 23 ohms) and Salnotes Zero (108 db/mw and 32 ohms) and it's a very slight popping, not really annoying, also CCA CA2 (112 db/mw, 23 ohms, really sensitive) and here the popping is definitely more noticeable and annoying, but even with these really sensitive iems, the noise reduction is enough for me to not notice any hissing after the noise reduction happens.
It seems only CS43131 with DRE disabled (still good enough noise floor and SNR at 50mv) and ESS dacs are flawless dacs with sensitive iems, but it also comes at the cost of much higher power consumption. More work needs to be done in the sub 10$ range, but CX31993 is as close as it gets, or Apple Dongle but 0.5 Vrms in europe and crackling in some tests and scenarios.
So I tried the cmaj test file with DA06 and this test makes the noise shaping very evident, if you play the test at very low volume, just enough to hear the sound only a tiny bit, you will see how the noise floor is exposed and hissing is revealed the three times there is something going on, but then the hissing just disappears with a bit of popping each time there is silence in the test. I seem to hear it much more clearly from the right side, though, no idea if it's because the DAC's noise floor is worse in the right channel or if my hearing is worse in the left. Salnotes Zero is enough to expose this, we are not talking about unusually sensitive iems here.
The same thing happens with Jcally JM6 Pro, but from a much higher level, extreme hissing in the budy sections and the noise floor is just reduced a bit in the silence sections, hissing is still very obvious even when the signal level is really low and there is silence in the song. This thing is probably a sub 70db SNR at 50mV without this trick.
So all in all, it's just not true that standalone CX31993 without the opamp is dead silent with sensitive iems, it is just using tricks to hide the noise floor quickly, after about 100-200ms of the signal level getting really low, but at the end of the day, all these cheap dacs, like CX31993, CB1200AU, KT02H20 etc are just very far from DRE off CS43131, ESS, etc, all these dacs are just flawed and have one issue or another, but I think this one is the best if you don't care about integrated EQ and also want very low power consumption.
Also interesting that, based on all the devices I've tried and relating them to the numbers I've seen published in reviews in terms of noise floor and SNR at 50mV, it seems around 80db is the cutoff point for these standard sensitivity iems (107-108 db/mW, 16-32 ohm) to not expose the noise floor, CX31993 trick lowers noise floor by about 5db according to testing that was done in this forum.
So since CX31993 with trick is around 81-82db SNR at 50mV from the tests and approximations I've seen, without the trick it would fall below the 80db mark and the noise floor is exposed.
New here so I didn't want to start a whole new thread for this, but I'm currently in this search and feeling a bit at wit's end. I have Beyerdynamic MMX 330 PRO headphones. I've never had a DAC before, but my goals here are to solve a bit of a noise floor issue with the mic, ensure I'm getting the most out of sound quality, and make switching between my MacBook and Windows laptop a little easier. Ideally all without breaking the bank. Here's what I've tried so far:
  • Apple USB-C to 3.5mm - sounded fine, portable, cheap, but introduced this high-pitched whine to all my recordings, so it's sadly unusable for my purposes. Bummer.
  • Fosi K7 - solved the mic noise floor issue, no whine, but after two hours swapping between the K7, Apple dongle, and plugging the headphones straight into the 3.5mm jacks while testing with high-quality FLAC files and games like Marathon, the difference in sound quality was barely noticeable even when actively listening for it. My hearing is good, so maybe I'm being overly skeptical to avoid placebo, but for $200 and not portable, I needed the sound quality to be a noticeable step up in casual listening to justify it. I've seen a few reviews mention that the MMX 330 PRO headphones don't really need an amp though, so perhaps that's part of it.
  • Hidizs SD2 - again not a significant change in sound quality, but it solved the mic issues and is extremely portable. However, the design blocks the other ports on my laptops and it's so aggressive with power saving/thermal management that it shuts off nearly the instant there's no audio playing, so whenever audio does play, I miss the first couple seconds of it. Two very frustrating flaws.
I have a list of additional ones that seem at a glance to meet my requirements: Jcally JM6/7/12/20/etc, FIIO KA15, Qudelix-5K, HiBy FC1/2/etc, EPZ TP35 PRO, on and on in a wide range of prices and apparent quality. But it's just such a rabbit hole of conflicting information, guerrilla marketing, and sponsored videos masquerading as reviews, so I'm really hoping somebody here can guide me in the right direction as this forum continually comes up in searches as being super knkowledgble. Any advice?
"Keep using the laptop ports until you hear something (which may be never)" sounds like a fine option to me in your case. Most people buying dongles are not replacing an onboard headphone jack, they're adding one where none exist using the dongle to smartphones and the like.
Yeah, in terms of sound quality, I'm happy with the laptop ports and don't need more volume, but unfortunately I still need something because of the noise floor issue with the mic. Additionally, when plugged in via 3.5mm on my MacBook, for some reason I have zero control over input volume with these headphones. Doesn't matter what I've set the value to; it's just super loud until I lower it to about 3%, then nothing at all. Plugging in via USB-C fixes that immediately.
The reason I'm going for a dongle is because it seems cheaper and far more portable. My Windows machine and MacBook are rarely in the same place so a single desktop solution doesn't really work, whereas just leaving a dongle connected to my headphones is ideal. I really wish the Apple dongle didn't introduce that whine. I don't get it.
Frankly, if you're not too critical of the sound quality on the listening side, I would suggest simply spamming all the no-name sub-10usd dongles out there that are the right form factor until one lands the punch :p
do you guys think the jcally jm7 max (or similarly cx31993 + sgm8682) could power the hifiman edition xs enough?
Edition XS has 110dB SPL/1V at 14Ω.
A single-ended SGM8262 dongle (e.g. JM20MAX) can output 2V into 14Ω, hence 116dB SPL with the Edition XS.
A differential SGM8262 DAC (e.g. FiiO KA15), with a differential headphone cable for the XS, can output 2.6V into 14Ω, hence 118dB SPL.
For reference, I rarely listen louder than 90dB SPL Peak.
The Edition XS + SGM8262 can play about 7x louder than that.
___​
<- my usual loudness
____________________​
<- Maximum loudness of Edition XS + SGM8262
now im concerned if sgm8262 based dacs could handle it
14Ω is not a problem:
