Best cheap USB-C headphone dongles?
Give it a go and if you find something not working correctly give me a shout - It should support most devices with PEQ now - but I don't have time to test things and manufacturers do come out with new hardware (and even some firmware updates) that make it a little bit difficult to keep it up to date.
But I am due to release an update in a week or 2 when I will also support PEQ on various Bluetooth headphones, but only ones that have underlying PEQ support.
That's awesome news. Any work going towards an Android app version? I primarily use my phone w the protocol max. It's a chore to drag out the laptop every time I want to update the EQ and I don't trust the Walkplay app.
Thanks! I played around with the version on obodio.squig.link, and I've made 1 pull request, and 3 issues already. But it's very convenient (much better than what I was doing before: I was using squig link, but then exporting the EQ's to EqualizerAPO's format, running it through my converter script, importing them into fiiocontrol.fiio.com, and then activating them).
A couple of things that the Web App has that I wish the squig link did however are:
  1. Little circles on the graph for each filter, that let you drag them to adjust the gain & frequency
  2. The ability to manually specify a master/global gain (when playing with EQ's I like to keep a consistent one, so that I can easily compare the sound of different changes I make, also so my ears aren't hurt if the gain suddenly goes up).
Who is the correct person to ask for these features? (or is there already a website using devicePEQ that has them?)
Have a look at my more advanced features on Pragmatic Audio => https://www.pragmaticaudio.com/head...K&F7=7200&Q7=1.1&G7=-4.8&T8=PK&F8=0&Q8=0&G8=0
I have a visualizer popup to visual and drag filters around to the shape you want and a few other advanced features. The main squig.link Cringraph codebase is a bit messy though - I developed the devicePEQ with a 'clear separation' as the Cringraph needs allot of work so I felt best to leave it alone.
And I am planning on writing a full Android (and IOS) app as the permission models with WebApp even in Chrome, is pretty limited, for example, I found there are 3 different approaches to bluetooth device configuration and only 2 can be supported in Chrome. And most local network 'API' use 'self-signed' certificates which causes issues in modern 'secure' browsers. And since I want to add more network and bluetooth devices that have PEQ, I am coming across more and more of these limitations, so a dedicated App is better long term.
But that will come in a few months, I have a pretty limited prototype but got very busy with other stuff.
I've tried it, and I've decided that the usual interface is better (where you adjust the parameters of your filters with your arrow keys, although it would be nice if instead of doing 1 Hz increments, the frequency adjusted the 2nd most significant digit),
Some random feedback for things you could to do improve your "visualizer":
  • Adjust the vertical display range of the graph (preferably just make it match the cringraph range). In particular, it was too small when I had a filter with a high gain next to one with a low negative gain (so the nob for the filter was way out of range of the graph).
  • show the other lines on the crin graph and not just the target and original frequency response (e.g. I often have another line showing a different EQ, or another headphone I'm trying to "simulate")
  • have an option to make one of the lines (specifically, the raw fr) as the baseline, which is what the fiio control graph shows
Other suggestions:
  • have an option to make changes to the EQ be applied live to the device (like fiio control does).
  • not have to reconnect to your device every time you push/pull to it.
  • have a button to download a CSV for each line shown (like other squiglinks have)
Has anyone had a Ugreen on a KT0210? It's very noisy and muddy. I haven't seen the measurements. What do you think?
just bought a Fiio Jiezi .
couldnt find any comments about one on this forum, but as it is only £13 , if it sucks i wont lose much.
only want something at the moment for iem use, which is good as it dont have a lot of power.
has peq with the app which will be useful.
FYI, there are some issues with the PEQ see: https://www.audiosciencereview.com/...e-dac-headphone-amp-review.62928/post-2532110
In particular, there's a bug with high shelf filters that can cause things to get dangerously loud.
that is a concern.
thanks for the warning
have briefly read the linked post and i have to admit a lot of it does not make sense to me.
my take away from it........
make adjustments with earphones out and i will avoid any potentially ear damaging shocks!
is this correct?
I've just got JCAlly JM7 Max and can confirm it has an awful/fairly strong volume fade-in at the start of playback.
Bummer. I was getting ready to buy one for PC duty (to drive an external amp and speakers). Why would they implement such a thing? Is it to reduce power consumption when there is no playback?
Any other dongles in this price range (around $25) that would provide 1.5V-2.0V to an external amp and not have such fade-in issues?
that is a concern.
is this correct?
Yup! You only need to worry if your EQ profile has a high-shelf though. If the volume doesn't get much louder when you activate such a profile or change the parameters of the high-shelf filter, you can put your earphones in.
Well I've got no problems with the FiiO melody, it's more expensive though.
well for the £13 i paid for the Jiezi its difficult to find fault.
the eq was simple to setup (even for me) and it drives my Ollo X1 just fine.(tried just out of curiosity)
as my intention is just iem use it seems to be just what i needed.
i just wanted another option for when its too hot for my HDB630.
sorted!
So you're not getting any initial audio cut-outs when restarting playback?
I've found the following, when doing some research on it:
While the Snowsky Melody is highly efficient, its implementation of the CS43131 chip's power-saving features can cause two distinct issues when restarting playback:
  • Audio Cut-off (The "Wake-up" Delay): If no audio has been played for more than 5–10 seconds, the DAC enters a sleep state. When you hit play, there is a roughly 0.5-second delay where the first half-second of the song is muted or cut off while the chip wakes up. This is often mistaken for a fade-in.
  • Static or "Hump" Noise: Some users report a brief static sound or a slight "thump" when the DAC wakes from its power-saving mode (DRE - Dynamic Range Enhancement). This occurs as the chip stabilizes its voltage rails for playback.
Is there any way to disable these power saving features on these dongles?
Hmm, maybe it's an OS setting I have? I've just tested it and I don't get any of those issues (although I have DRE off).
Maybe it's because I have USB selective suspend off?
I do get the problem, it's just so minor I didn't notice it on music. However, when I tested a video, I did notice it, albeit it was very slight. In contrast, when playing a game and cycling through options in the menu, the sound effects did not play until after I cycled through a few options.
If your on Windows like me, SoundKeeper is the general solution to such problems. But I don't use it (my father does for a toslink output). The setting that I got to work was to name the executable SoundKeeperAllSineA0.0001.exe (which plays, on All sound devices, a 1Hz Sine wave, at an amplitude (relative to full volume) of 0.0001% (which is the smallest number that worked for me when my Melody is set to 32-bit audio)). The sound it plays is completely inaudible, but prevents the problem from occurring. (Interestingly, my father;s Toslink output only required the Zero setting, which plays all-zero PCM data).
I'm not sure whether this is Windows 11's fault, or the Melody's. I can't seem to reproduce the problem with my phone though.
For the KA15 someone found this solution, I don't know if it works for the Melody (as I don't have a problem, I can't test if it solves it!) (this doesn't work on the melody)
- One can disable sleep mode (hold volume down before connecting to USB) to disable this effect.
EDIT: suddenly now I am having a problem (there's a buzzing sound when I'm not playing anything, and it is taking a second for sound to start, and the buzzing to stop. I don't think this has ever happened before (the buzzing is quite noticeable). I'll update once I find a solution) Unplugging and re-pluging it in fixed it. Using SoundKeeper as explained above will also fix it.
@escape2, you were in fact right! the problem does occur, I just didn't notice it as it was so minor. I've updated my post with a solution that should hopefully work with other devices.
Just mentioning as I've noticed a new dongle from Faaeal, one of my favorite flathead brands, but not one with universally good products.
FAAEAL FDC03 based on CX31988 with 3 switchable sockets for 3.5mm, 4.4mm and 2.5mm akin to cables with switchable connectors.
The price is $20 for me as it includes 23% VAT.
Haven't seen CX31988 dongles in recent years, last time possibly around when JCAlly had JM6-4 and JM6-2 dongles, which were 4.4mm and 2.2mm respectively. It is hard to find anything about the chip, but it is around 1Vrms and seems to be primarily used instead of CX31993 in dongles with balanced connectors. Personally I'm not particularly interested in the switchable sockets feature and would rather like a lower price with just 4.4mm, but there might be people which would find it handy so it is fine there is such a product. The big question is if the output from this chip is balanced or not ;)
Their previous 2 dongles (hence 03 in model name I guess) were based on KT Micro KT4099 (rare) and Realtek ALC5686. The KT4099 was highly hyped for a short time in some Facebook groups, with mentions of boosted bass, however after a few months people were switching away from it, because they found the boosted and buzzing bass became fatiguing over time. I have it, and can indeed say there is some very audible weird buzz in the bass, not really usable.
Have you considered the Fiio Tiny B or JIEZI? (they are 4.4mm, but are unbalanced; not that you're ears will be able to tell the difference).
Hmm, the pictures show it uses 4 pins, and it says it doesn't support microphone or controls. So if it's unbalanced, why not just use 3 pins?
Thanks, I already have my balanced 4.4mm needs covered by Aiyima H3, and by all means I don't hear any differences as long as the extra power is not in the play. That said I'm always looking for excuses to purchase something though, so a tiny "cable" type dongle with balanced 4.4mm specifically for crosstalk beyond any theoretical doubts of transparency, might be an argument. Still, the performance of CX31988 probably isn't much better than CX31993, and the 1Vrms output is a bit low to spend money on yet again anyway.
Those are the same 4pin connectors as commonly used in cables with switchable plugs, so it is a mass produced off the shelf part, which would make it cheap. There is no reason for 3pin variant of the connector to exist aside of the specific use case of such unbalanced + switchable connectors dongle. Even if those are one of the "standard" Mini XLR connectors or whatever already in wide use (I don't have experience with Mini XLR), then having 3pin one with wiring for 4.4mm would probably be some custom order/require more work than just wiring the DAC's end of the switchable connector.
