JCALLY X Crinacle AP6 = 199CNY
The absolute best USB dongle is the E1DA #9039S.
Personally, I'd like to see a dongle with the ALC5686 + SGM8262.
(Simply because the ALC5686 sounded more detailed than the CX31993.)
I think I saw some measurements showing worse performance of ALC5686, but don't remember where they were, so perhaps they weren't "proper".
If Moondrop Click is on ALC5686 then it is on L7AudioLab, SiNAD seems very ok, but then linearity...
https://www.l7audiolab.com/f/moondrop-click/
One more thing we also know is from @staticV3 current draw measurement, Moondrop Click draws 25.3mA vs 11mA of CX31993 dongles. While not necessarily bad, it about matches 26.5mA of "lifeme Hifi Audio Pro" which I think is the CX31993 + Max97220 variant?
In my case I have Avani on ALC5686 and I've always picked CX-Pro CX31993 when comparing. For my ears Avani sounds soapy/poorly defined at times, and actually a bit shouty? Generally seemed very much like my ALC897 onboard (75dB SiNAD at 0.92Vrms, 3.2mW at 32Ohm, 2.7mW at 300Ohm) just with a more power on tap. And I was very hyped for Avani, as I specifically picked it after reading Andy/donglemadness... (ye I should knew better...).
It is hard to imagine for me, how something can be noticeable better, beside power and functionality.
I would like to add the Sonata BHD (non-Pro). They can be available for as low as 16USD on both Lazada and AliExpress, rendering it the cheapest dual output DAC available. It also features near zero DRE distortion like JM20 Max on the list, very low noise and have adjustable gainSo, as of now, what are the best cheap USB headphone dongles that have output > 1 Vrms?
Since we're talking about the best "cheap" dongles, even a few dollars should matter.And onboard PEQ is not a must-have feature. DRE artifacts or any other performance issue should not be present.
Looking at the very current market offerings, these come into sight:
In particular, the Hiby FC3 is priced very nicely for now. If it measures same as the FC3 w/ display, it will make a very nice, no-frills USB dongle.
- TRN Black Pearl (with new firmware): $33.29 at AliExpress (BrightAudio)
- FiiO Melody (with new firmware): $39.99 at Amazon.com
- JCally JM20 Max (not completely free of DRE distortion, though): $21.15 at AliExpress (CKLewis Audio)
- JCally JM20 (not completely free of DRE distortion): $18.97 at AliExpress (CKLewis Audio)
- Hidizs SD2: $31.99 (w/ coupon) at Amazon.com
- Hiby FC3 (no display): $23.02 at AliExpress (Hiby Official Store)
EDIT. The FC3 can be one of a kind with respect to
Any other dongles that I've missed?
- Price < $25
- No DRE-induced distortion
- Low noise for a dongle with a unity gain buffer (only behind the state-of-the-art, top-of-the-line DACs with over 120 dB SINAD)
- Relatively low power consumption and low heat thanks to integrated chip design (e.g., lower than op-amp design like the JM20 Max)
Pros:
+ 4.4Bal Powerful: Vol16/100 for ATH-R70x, Moondrop Para
+ 3.5mm inline microphone support
+ Detachable USB Type-C
+ Solid build
+ Plug and play
Cons:
- Fade-in when changing songs in exclusive mode
- Does not support 88.2kHz, 176.4kHz, and 352.8kHz
- No volume button
- No gain switch
- No PEQ
- No DAC filter options
- No RGB LED
View attachment 491817View attachment 491818View attachment 491819View attachment 491820
Oh ok, I was misleaded by your first screenshot, didn't notice it was about ADC.
Do you know what bridge chip is used? The missing 88.2, 176.4, 352.8 kHz may indicate an SPVxxx, which would include an ADC (and DSP, even if it’s not used).Jcally doesn't specify an ADC on the box, but it actually supports an inline microphone as shown in the picture.
I have searched but can't find any information about the bridge chip used by the AP6.Do you know what bridge chip is used? The missing 88.2, 176.4, 352.8 kHz may indicate an SPVxxx, which would include an ADC (and DSP, even if it’s not used).
I completely missed the CX31993 DAC. If I’m not mistaken, it has its own USB interface (no need for a separate USB bridge), and also has an ADC for mic. input.I have searched but can't find any information about the bridge chip used by the AP6.
