SlowLife
- Joined
- Apr 13, 2022
- Messages
- 39
- Likes
- 75
Did they measure current draw?
"17.39ohm 0.144mW:50mV" and "17.39ohm 0.144mW:10mV" or "17.39ohm 0.144mW:30mV"
Hi and welcome to ASR.I already have a Tempotec Sonata HD Pro, but I miss the mic support.
Is there anything with the same sound quality, ASIO support, and mic support?
I've checked Tempotec's and Tanchjim's product ranges yesterday.Hi and welcome to ASR.
If you strictly need ASIO support i cannot recall any dongle with mic support.
mic support is generally done via and ADC integrated with the usb bridge or with a complete codec chip thati ntegrates DAC, ADC and bridge.
ASIO drivers are available only for Savitech, Comtrue and Xmos usb bridges and non of them have and integratec ADC, so i cannot remember any dongle based on them supporting mic input.
Not specific to Jcally, as you can see in the topic you linked it's a common behavior for many dongles, it's due to power saving features since they are originally intended for mobile use with a smartphone.I bought the JCALLY JM7 Max during an AliExpress sale.
I connected it to my Windows 11 PC and played a test audio in the sound settings, but it played with a fade-in.
There's a glitch where playing music from silence causes it to fade in. It's awful.
Right out of the box, I was disappointed when playing the test audio. “Not again,” I thought.
The JCALLY JM30 has a similar issue.
It's not a fade-in, but when playing an audio file, the first 0.5 seconds are missing.
Information about this is being shared in a dedicated thread.
I own two JCALLY products. Are they all like this?
I've wasted money twice now.
Yes, PEQ filters on the Hi-Max dongle work as intended except that the Q factor of a low-shelf filter has no effect. But shelving filters are not that useful, anyway.@jkim is the hi-max cb1200au dongle has accurate EQ. like does it have similar output if the same EQ parameters was set in the walkplay app and something like equalizer apo?
Hi and welcome to ASR.Just want to share my subjective opinion on 3 cheap dongles.
GraveAudio DA06 (CX31993) > Generic ALC5686 > Hi-MAX (CB1200AU)
The DA06 can step down to UAC1 (USB Full-Speed, 96/24) without artifacting (crackling) while the other 2 can't.
Both the DA06 and the ALC5686 have no noise when it is silent but the Hi-MAX does (used with CCA CRA).
The CB1200AU seems to be inferior to the ALC5686 (105 vs 124 dB SNR, -85 vs 92 dB THD+N) judging by the datasheet screenshots I jacked from BiliBili. The same DAC is also used in Moondrop Quark 2.
It also does appear to have a stereo ADC, which I found quite unique.
| Hi-Max | Grave Audio DA06 | |
| Output impedance | 2.5 Ohm | 0.2 Ohm |
| Max unclipping output | 0.95 Vrms | 0.98 Vrms |
| 102 dB | 106 dB |
I have no doubt it was noticeable in your experience. As you may recall, I measured the dynamic ranges of the Hi-Max and JA11 w/ TinHifi firmware. The JA11 w/ TinHifi FW is a tiny bit (1 - 2 dB) noisier than the Hi-Max. Based on RAA's measurements, the three devices' DRs (virtually same as SNRs) are best estimated as:I think CB1200AU has very similar noise floor to JA11 with tinhifi firmware, so noise floor is definitely very noticeable in my experience.
| FiiO JA11 w/ TinHifi FW | Hi-Max | Grave Audio DA06 |
| 101.5 dB | 102.5 dB | 107.0 dB |
| 75.5 dB | 76.5 dB | 81.0 dB |
Thank you for reporting and resuming it here and to Roman for his great work!Finally, both the Hi-Max CB1200AU and Grave Audio DA06 (CX31993 with no op-amp) have been measured by the same reviewer, Roman at Reference Audio Analyzer. Since the results must have been obtained in the same testing condition, we can make an objective comparison.
Hi-Max CB1200AU and Grave Audio DA06 pictured:
View attachment 475839View attachment 475840
These two dongles are pretty cheap at AliExpress.
Output impedance and maximum output:
These are basically 1V output dongles and as such suitable for reasonably sensitive headphones and IEMs. The Hi-Max's 2.5 Ohm output impedance means that its max output will drop a bit when paired with low-impedance phones.
Hi-Max Grave Audio DA06 Output impedance 2.5 Ohm 0.2 Ohm Max unclipping output 0.95 Vrms 0.98 Vrms
1 kHz sinusoid tests at -1.0 dBFS under no load:
View attachment 475887View attachment 475888
Hi-Max's THD is substantially higher than the Grave Audio's.
1 kHz sinusoid FFTs at -60 dBFS under no load:
View attachment 475894View attachment 475895
Hi-Max's noise floor is also slightly higher (4 dB higher; see below) than the Grave Audio's. These measurements also indicate that these two devices do not employ dynamic range enhancement (DRE) to artificially reduce noise at low levels.
Measured signal-to-noise ratio referenced to max output:
Although this difference is not very large, it seems that these noise levels are right on the borderline between hissing and silent background according to @mc.god's observation in the above.
Hi-Max Grave Audio DA06 102 dB 106 dB
THD vs. level under 24.5 Ohm load:
View attachment 475897View attachment 475898
THD performance of the Hi-Max is again somewhat worse than the Grave Audio at higher levels. In practice, however, harmonic distortion shouldn't be an audible issue for either device.
According to the data shown so far it appears that the Grave Audio DA06 performs a little better than the Hi-Max with respect to distortion and noise. However, there is one area where the Grave Audio has an issue.
See jitter tests:
View attachment 475901View attachment 475902
Contribution of random jitter is quite noticeable on the DA06's response whereas jitter of any kind is absent on the Hi-Max's.
So, which is a better choice? In my view, either should be fine in its use case (i.e., a tiny dongle for reasonably sensitive phones). But the PEQ feature of the Hi-Max is a big, surprising bonus for a dongle at this price. One may just need to see if its slightly higher noise level is noticeable for the headphones, and if its higher output impedance drops its output too much (in most case, it should not).
100% agree, but since they are so cheap I'd say "get both and chill!"Given all the information, for a cheap 1V dongle I would recommend:
- Hi-Max (CB1200AU), based on its overall performance and onboard PEQ;
- Grave Audio (CX31993) or other CX31993-based dongle, if low noise is top priority and onboard PEQ is not necessary.
Would you be more specific on this? As for the Hi-Max, does it not support UAC1? Or does it support UAC1 but not without crackling?The DA06 can step down to UAC1 (USB Full-Speed, 96/24) without artifacting (crackling) while the other 2 can't.
I have a setup where I connect a 3.5mm from my laptop's dock to my desktop's line-in, so I can hear both audio at once.Would you be more specific on this? As for the Hi-Max, does it not support UAC1? Or does it support UAC1 but not without crackling?
