Uhm, I don't know if it can be related to your issue or the fact that it's recognized at max 96 Khz on my OS, but now I turned on the usb port where the CX is plugged (it's a usb hub with switch for each port) and it didn't showed up in OS:Interested to see if you have the issue I do moving around. If you have the chance to try of course. Good to know it works on linux as I have not plugged it into the PC yet.
in events i found this:
Bash:
[ 6264.838600] usb 1-1.1.1.2: new low-speed USB device number 12 using ehci-pci
[ 6265.695125] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6266.547054] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6266.547387] usb 1-1.1.1-port2: attempt power cycle
[ 6267.718980] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6268.571113] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6268.571340] usb 1-1.1.1-port2: unable to enumerate USB device
[ 6316.739015] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6317.595007] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6317.595262] usb 1-1.1.1-port2: attempt power cycle
[ 6318.762890] usb 1-1.1.1-port2: Cannot enable. Maybe the USB cable is bad
then played a bit moving the dingle in the usb port and pressing a little on it and this showed up
Bash:
[ 6320.090596] usb 1-1.1.1.2: new full-speed USB device number 19 using ehci-pci
[ 6320.123438] usb 1-1.1.1.2: device descriptor read/8, error -32
[ 6320.251452] usb 1-1.1.1.2: device descriptor read/8, error -32
[ 6320.358788] usb 1-1.1.1-port2: unable to enumerate USB device
[ 6367.986601] usb 1-1.1.1.2: new full-speed USB device number 20 using ehci-pci
[ 6368.066590] usb 1-1.1.1.2: device descriptor read/64, error -32
[ 6374.514605] usb 1-1.1.1.2: new full-speed USB device number 22 using ehci-pci
[ 6374.624178] usb 1-1.1.1.2: not running at top speed; connect to a high speed hub
[ 6374.644548] usb 1-1.1.1.2: New USB device found, idVendor=3302, idProduct=3365, bcdDevice= 0.01
[ 6374.644574] usb 1-1.1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6374.644583] usb 1-1.1.1.2: Product: CX31993 384Khz HIFI AUDIO
[ 6374.644590] usb 1-1.1.1.2: Manufacturer: TTGK Technology Co.,Ltd
[ 6374.672141] input: TTGK Technology Co.,Ltd CX31993 384Khz HIFI AUDIO Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1.2/1-1.1.1.2:1.3/0003:3302:3365.0008/input/input37
Now the dongle is recognized by OS again as max 96 Khz.
I'll do other test without the usb hub and with a different usb-c/usb-a adapter.
. It's still very random errors like a 90s graphics card. I can get it to distort on the right channel at times due to whatever connection thing it is, and I can also (based on ears only) get it to output at a sampling rate below 44khz, or at least some other shenanigans which sounds crappier and low pass filtered.
