Best budget DAC?
rohitss
Looking to upgrade from a MOTU M4 and was looking at a few different options:
Topping DX1 II
FiiO K11 R2R
iFi ZEN DAC 3
Fosi Audio ZH3
Anybody have a favorite from these options or another suggestion?
I don't think any of these are an upgrade from the M4 unless there's something it's doing that you don't like. What's making you want to upgrade?
Wanted to try a dac with a different sound signature from sabre so the Fosi is AKM, iFi is Burr-Brown, FiiO is an R2R, and the topping while sabre has a better amp than the M4.
Could stretch the budget a bit for a meaningful upgrade to like $400.
Should have said in the first message - "Welcome to ASR!" - and in general you will find that this site provides a lot of evidence that the idea that DACs have a distinctive sound signature is a myth.
Good DACs won't and the vast, vast majority of them don't. If they do, something is wrong.
(This is not to say DACs don't sound different to people... but in nearly every case the difference can't be heard in blind testing. So... placebo effect, in other words.)
The M4 has good objective performance, (I just bought one myself) and if you have $400 to spend on audio upgrades, better to look into headphones, speakers, room treatment, etc.
The M4 has a pretty mid headphone amp, it is true, so if your cans need more power you could always add a HP amp, but the DAC itself is not going to change anything about your listening experience.
Cool, thanks for the help!
For headphones I have the Sennheiser HD6XX, Philps Fidelio X2HR, Beyerdynamic DT 990 Pro, AKG K702, and a few other pairs.
For speakers I have the JBL 305P MKII Studio Monitors connected to my M4.
Would you recommend the JDS Atom Amp 2 or some other piece of gear?
I have an Atom Amp 1 and zero complaints about it, so personally I think the Atom 2 would a good way to go for an amp.
The 305P MKII are also good speakers, but I think upgrades are possible in the $400 range, you can probably at least get a pair of 308s on marketplace for that money. I guess it mostly depends on whether headphone or speaker listening is your priority right now.
Thanks I think I'll go with the Atom 2 then, could use some more juice on the cans. Pretty satisfied with the speakers + subwoofer for casual listening.
Honestly none of these sound different from the M4 - DAC chips don't have audible signatures at this level, and R2R's higher noise/distortion is still below audible. A real upgrade at is features, not sound: balanced out, remote, EQ. If you just want a different flavor, keep the M4 and save the cash.
Topping DX1 II is pretty damn great right now
Sounds like simple upgraditis. :) I would just keep using what you've got....
Pulled the trigger on the Atom 2 and got $50 back as Shop Cash, seemed like a good deal!
The FiiO K11 R2R is providing excellent results in my Schiit stack. I use the volume control on the K11R2R as it has a great feel and clear display. The Vali3 volume is permanently set at 50%. I can adjust the tone to suit my old ears, often on a track by track basis.
That little stack is lovely.
DACs are extremely dependent on the feature set they support for your needs. If they don't support the features and connectivity you need, their SINAD performance is meaningless for your use case. Plenty of great DACs, but they are quite specialized in too many cases. Any competent DAC built after 2010 is great if it supports the feature set you need, never mind the SINAD. Anyone that claims they can hear the difference between a 102dB and a 120dB SINAD in DACs probably slipped from their mother's hands as a baby from a second floor, honestly. :-)
With the performance available it's hard even for an amateur like me to go wrong for that. Features are definately the prioity for aye or nay. Would like to add sockets and reliability as rather important too.
A bit tricky to find combos for desktop or tv usage without wifi/bt....
The Fosi Q6 dac is simple and good, has USB, optical, coax. Powers from USB. Has an AKM 4493 dac chip.
