Pjetrof
Title says it all.
what would you guys recommend, which streamer has the same quality as the benchmark Dac?
Atomic Pi
I do not care Roon
It's a kind of way of life. Open source yes, Windows Mac and costly licences no.No roon, no music, unfortunately.
Unless someone can provide evidence to the contrary, all you need is a Raspberry Pi. The 4 has a lot more power than the 3 and has USB 3 as well as USB 2. Get a dedicated PS, an inexpensive case (to keep the dust off), µSD card of at least 8 GB, your SW of choice, and you're off.Title says it all.
Title says it all.
Just streaming service.
This includes a DAC, doesn't it, like the (discontinued) Arcam rPlay? You could use the Toslink output, but then you are paying for a DAC you're not using.The new streamer from Audio Engine looks promising - link: B-FI streamer
I thought they were discontinued, any suggestions how to get some? I need four.Chromecast Audio using the digital output? I use one with my RME ADI-2 and it works a treat, without any sonic impairment. Maximum resolution is 24/96, but that is already more than makes sense.
