This is a question aimed that those who use or are familiar with room correction/dsp with non-SAM/GLM monitors.
In this instance, we assume the speakers are placed as optimally as possible the room they’re in (domestic setting).
In regards to the best possible outcome with Genelec speakers that are not SAM/GLM compatible, which approach would yield the best results:
A) Using REW to measure the in-room response and curtailing bass prominence (for instance up to 300Hz) with dip switches (repeated measurements until most obvious peaks are reduced) and then applying EQ (from REW measurements) to make the final small adjustments?
Or
B) Keep the speakers with all dip switches disengaged, and use REW to calculate the optimal EQ for the room correction?
Thanks
Or
Thanks
